Old 10-01-2013, 05:54 AM
jkeijner jkeijner is offline
Default question about PT LE, 9, 11 upgrades/crossgrades
about a year ago I crossgraded my PT 8 LE, that came with my 003 rack to PT 9. so I have 1 PT 9 license on my ilok, now I want to upgrade to 11 the cheapest way
and
I own PT 8 LE software with a code(no ilok, no hardware)
I also own PT 7.4 LE software with a code(no ilok, no hardware)
and I own an eleven rack that came without pro tools.
my question is: what would be my best option to upgrade to 11?
and can I reuse my 003 or use my eleven rack to crossgrade LE to 11(so i can keep PT9)?
thnx!
grtz,
Jur
Old 10-01-2013, 07:22 AM
sunburst79 sunburst79 is offline
Default Re: question about PT LE, 9, 11 upgrades/crossgrades
and
thnx!
grtz,
Jur
Use the Eleven Rack serial if its not been used previously. The old PTLE auth codes are worthless except for running PTLE.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 10-01-2013, 07:30 AM
nst7 nst7 is offline
Is there a reason you want to keep PT9? PT11 gives you a license for PT10, if you're just concerned about certain plugins not being AAX yet.
Old 10-01-2013, 08:38 AM
thnx for the replies!
just realized that my eleven rack was 2nd hand and have no way of knowing if it is even registered already(cant check that?)
only reason to keep PT 9 would be the ability to run PT on muliple machines or give it to someone else.
guess no other option then to upgrade from 9...
thnx all!
Old 10-01-2013, 05:53 PM
thnx all!
All I can suggest would be trying the upgrade path and seeing if it will take the serial. Unfortunately there's no serial number upgrade checker.
Scott
Core 2 Specs Page
Old 10-02-2013, 03:18 AM
worth the try...
I've send an transfer of ownership form to the previous 11 rack owner.
then I came across the following note in the transfer document:
"Please note: Purchasers of previously owned software licenses are not entitled to upgrades, license replacements, install media, or support at
no charge. Pro Tools HD upgrades are only available to customers who own a compatible Avid hardware product and/or previous qualifying
software license." also bundled software is nontransferable
so I'm not 100% sure..
Old 10-02-2013, 07:54 AM
That paragraph does not apply to your situation. Neither does the transfer of ownership process.
You just need to find out from him if he used the Eleven Rack serial number for the LE crossgrade. That's it. If he did, then you can't use it. If he didn't, then you can use it. Nothing else is applicable.
If you still want to have him do the transfer of ownership, that's fine. The only benefit to that will be if there's ever a safety recall (you will be notified), or if there is an Avid hardware exchange offer in the future that might apply (like if they come out with an Eleven Rack v.2, and offer a trade-in discount to current Eleven Rack owners).
But none of that has any bearing on this serial number question.
Old 10-02-2013, 11:36 PM
solid! in that case i'm just gonna try that.
thnx for the answer !
Any PCI-x crossgrades? Actionmusic Pro Tools 10 2 10-21-2011 03:19 PM
Crossgrades from PCI to PCI-E discontinued ?? raregroove Pro Tools 9 1 01-20-2011 06:53 PM
Toolkits and up/crossgrades SoundGround Pro Tools 9 6 11-18-2010 03:45 PM
HD upgrades and crossgrades thekrynn Pro Tools TDM Systems (Mac) 5 11-27-2009 09:40 PM
Will there be crossgrades? Tiago Silva Pro Tools M-Powered (Mac) 0 04-06-2005 08:58 PM
