Old 06-19-2012, 07:58 AM
Firechild Firechild is offline
Default Key Command for next track selection ?
Can´t find it anywhere...
I´m looking for a key command to navigate through tracks. Similar to Move selection up and down but now tracks.
It is useful when working with MIDI, you have to select the track that will be the "active" MIDI thru channel.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 06-19-2012, 08:27 AM
Default Re: Key Command for next track selection ?
"P" for previous track, ";" for next track
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 06-19-2012, 08:34 AM
priorytools priorytools is offline
Rich.
I think think Firechild means in the mix window.
Is that right FC ?
I'd like that key command too . . . but I don't know it.
Anyone ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 06-19-2012, 10:37 AM
That only moves Edit selection for me, from track to track. I will move and select the track itself.
Actually the "missing" command should be useful in both mix and edit window.
Old 06-20-2012, 02:00 PM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
how about linking track and timeline selection?
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 06-20-2012, 02:55 PM
Ok, I guess you mean Link track and EDIT selection.
Yes, that is close, I will check out if it will do the trick for me !
Old 06-23-2012, 12:43 PM
No, it doesn´t work exactly as I want...
Still looking for a keycommand to step up and down between tracks. Independet from edit selection.
What is the key command for "link track and edit selection"? jkuehlin Pro Tools 10 5 10-21-2023 05:07 AM
D-Command Track Selection Cawbaby ProControl, Control|24, Command|8 1 04-04-2011 12:40 PM
Key command for playing selection in a single track? BobK88 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-01-2009 08:41 PM
Selection key command ? priorytools Pro Tools TDM Systems (Mac) 1 04-22-2008 03:40 PM
"Move Selection" key command LK7 Tips & Tricks 2 03-19-2007 08:10 AM
