Old 04-27-2012, 01:41 PM
Joeyohh Joeyohh is offline
Default SC48 not recognized by PT9.05
Hello,
Sorry if this is a n00b question..
Just upgraded to a new Macbook Pro w/Quad 2.8GHz i7, 4GB DDR3, OSX 10.7.3, Running Pro Tools 9.0.5.
Trying to connect to my SC48 via FWx (am NOT on VENUE 3 firmware yet). The computer seems to see it; D-Show (Fwx) shows up under sound devices in system prefs. However Pro Tools does not show it under playback devices and when exploring the Digi CoreAudio Manager it says "unsupported device". Also might be worth noting, when playing back from iTunes with Fwx selected in system prefs and FWX 1 and 2 routed to channels I get no signal.
Tried reconnecting and rebooting everything. Works perfectly when I connect my old macbook pro.
Any suggestions are greatly appreciated.
Thanks!
Joe
Old 04-28-2012, 12:40 PM
DigiTechSupt's Avatar
Default Re: SC48 not recognized by PT9.05
Couple of things to start with :
- clean uninstall of PT
- reinstall and make sure you install the digi 003 fw drivers
- still not seen -> go to playback engine and make sure it it set to the venue system
Avid Audio Tech Support
Support FAQ
Old 04-28-2012, 03:47 PM
Ok so;
Did a complete uninstall and reinstall of PT9. Installed the 9.06 updater. Still same problem and no dice. Again, VENUE is showing up under sound section of mac system prefs but does not play back through SC48 when selected. FWx does NOT show up under playback engine device tab, only built in input, built in output, and pro tools aggregate IO.
I didn't notice an option to install 003 drivers when installing PT.
Is Venue firmware version 3 required to run on PT9.06?
See screenshot below.
http://a1.sphotos.ak.fbcdn.net/hphot...33176467_n.jpg
Please help!
Joe
Old 04-28-2012, 10:12 PM
Avid Pro Mixing Support's Avatar
Avid Pro Mixing Support Avid Pro Mixing Support is offline
Sounds like you did not install the 002/003/FWx drivers, which are found here: http://www.avid.com/drivers (about halfway down the page)
VENUE FWx FireWire Option Card Drivers
Let us know if this works
-Rich
Old 04-30-2012, 10:35 AM
Success!
Me = Dummy!
Thanks for taking the time!
Joe
PT 9.06 on Mac with SC48 Tigerspill VENUE Live Sound Systems 4 02-10-2013 08:50 AM
PT 9.06 on Mac with SC48 Tigerspill macOS 0 02-04-2013 10:52 AM
PT 9 with SC48 J2sound VENUE Live Sound Systems 3 12-06-2010 10:08 AM
FWx on SC48 not recognized by Pro Tools LE Robert I VENUE Live Sound Systems 4 10-01-2010 12:55 PM
Sc48+pt le braxty VENUE Live Sound Systems 4 04-18-2010 11:00 PM
