Old 04-15-2012, 01:13 PM
J2sound J2sound is offline
Default Cue on Mains to Matrix
If I select "Cue on Mains" can I then route my cue up to a Matrix so I can mix with another channel i.e. Talkback?
Old 04-16-2012, 10:38 AM
vikingthor vikingthor is offline
Default Re: Cue on Mains to Matrix
Can't think of a way, other than doing a hardpatch; monitor out, to channel in. And assigning the channels in the matrix. Even a plugin on the monitor output can not be softpatch back within the console
Old 04-16-2012, 06:44 PM
Really? That's the only way to do it?
Old 04-17-2012, 11:47 AM
Brent Lind Brent Lind is offline
This is my monitor setup. I use an AES channel to loop it out and back in and then route to 2 stereo matrix outputs. Pretty silly, but until Avid comes out with a console with multiple solo busses I can't think of a better way.
However, being able to add in user defined channels is an excellent way to handle talkbacks and such, so there's that.
If you're going to do it, go AES, that way you don't add any conversions to the signal cahin.
Output to Mains On?off? FreeBlues Eleven Rack 4 05-02-2013 04:51 AM
Eq Sc 48 mains YellowDissident VENUE Live Sound Systems 2 05-21-2011 06:57 PM
Monitor mains on 002 c1jv 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-18-2006 09:45 AM
CPU noise through AC mains skylab001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-26-2004 06:35 AM
Mains Hum phamtec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-23-2001 12:58 AM
