Old 11-20-2017, 03:42 AM
IrelandM IrelandM is offline
Default I/O settings ProTools HD
To Users,
I would like to be able to record a single mono voice track but keep getting the following screen dialog how do I resolve the problem and set it up correctly.
Regards
File Type: png Screen Shot 2017-11-20 at 10.28.23 AM.png (55.9 KB, 0 views)
Old 11-20-2017, 04:40 AM
Southsidemusic's Avatar
Default Re: I/O settings ProTools HD
In PT goto Settings - i/o and there press default on all tabs, both in out and aux etc and that should do it for you.
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 11-20-2017, 06:27 AM
To Southsidemusic,
I have re-set all the tabs in the I/O settings to default but on creating a newly named session it still opens the session with multiple outputs.
If I create a new stereo mix through the I/o setup tab the Aux ins and Outs cannot be selected to even allow me to route a voice signal.
Regards
Old 11-20-2017, 07:54 AM
john1192 john1192 is offline
i think we need more / some system info .. audio interface, computer, OS being used .. all exact versions of system ..
and after that, what happens in a Blank Session ?? one track .. etc .. you see where i am going with this ... help us help you ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 11-20-2017, 11:07 AM
Do you have overwrite i/o settings enabled or not enabled?
Best Regards
Christopher
WEBHOME
Old 11-20-2017, 11:29 AM
The picture shows Out 1-2 being remapped to Built-In Output 1-2. So maybe the OP needs to check their Playback Engine first. It will be hard to record a vocal that way unless using the mic on the Mac.
Scott Gatteρo
Yessian
Old 11-20-2017, 11:40 AM
Looks like you opened a session that was started on another system? That usually requires some cleanup work. With that session open, go to Setup>IO>Bus tab. Anything that is in italics is a non-working path and can be deleted. Then go back to the Output tab and correct any path names, or delete all and hit the Default button. While you're in IO setup, go to the Inputs tab and make sure everything there looks like it should.
It takes a little trial and error to learn the IO setup quirks, but once you learn it, you can customize it to make your work flow better, and you'll also know how to solve these kinds of problems(which will happen any time you open a session from another rig)
ProTools 12 - Mouse settings EHart Pro Tools 12 9 08-12-2016 05:16 PM
Protools Settings - Tutorial jmlm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-01-2010 10:30 AM
Midi protools settings THE STATIC FACTORY MIDI 4 02-11-2009 04:45 AM
ProTools, Mac Pro, RTAS settings rtcstudio Pro Tools TDM Systems (Mac) 2 12-05-2008 01:23 PM
Cubase -Protools settings ---HELP HELP!!!!!!!!! Peter Martin Tips & Tricks 2 02-05-2000 05:32 PM
