Old 11-18-2017, 06:37 AM
simonyeah simonyeah is offline
Default Fade between two regions already with fades
Hey,
Anyone knows a shortcut/way to crossfade two separate regions that have already each fades in/fades out?
To do so, I am always obliged to clear old fades in/fades out and after do a crossfade.
But i would be so faster if it could be dont with a single keystroke?
Thanks in advance,
Simon
Old 11-18-2017, 09:12 AM
Default Re: Fade between two regions already with fades
I have a Keyboard Maestro macro for exactly that - might save you some time.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 11-18-2017, 10:58 AM
Alternately, delete the fades and start over
Old 11-19-2017, 01:26 AM
Thanks thought there was a better solution...
Envoyé de mon iPhone en utilisant Tapatalk
Old 11-19-2017, 04:31 AM
amagras amagras is offline
Try using the selection tool to highlight the portion of both tracks where you want to crossfade and press F.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 11-20-2017, 07:29 AM
Pretty sure that will only work over two crossfaded regions, not - as the OP was asking - a fade out/fade in boundary.
Old 11-20-2017, 08:40 AM
Yes that is precisely the problem...
Old 11-20-2017, 11:50 AM
john1192 john1192 is offline
tested:
1) if the 2 clips are right next to each other (I split a track using the "B" key - separate) and then put an out and in fade on the 2 clips .. i then dragged across just beyond each fade and hit the "F" key to make a crossfade and it works ..
2) if the 2 clips are NOT right next to each other (I split a track using the "B" key - separate and dragged them apart) and then put an out and in fade on the 2 clips .. i then dragged across just beyond each fade and hit the "F" key to make a crossfade and it creates and in and out fade at the Crossfade Amount in the Fades Dialog ..
Q: are you suggesting that the 2 clips that are Separated should have a crossfade on them with either
1) the empty space between the clips being used in the crossfade ??
OR
2) that the empty space between the clips be filled in with what is part of each clip ??
trying to understand the workflow you are asking about ...
cheers john
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 11-21-2017, 08:25 AM
Originally Posted by john1192 View Post
tested:
Try case 1 with two unrelated clips overlapping.
Old 11-21-2017, 01:53 PM
hi rich, yes, that works fine ..
two unrelated clips with a fade out on one and fade in on the other .. drag one over the top so they overlap and Hit "F" .. creates a crossfade !!!!
Fade-In and Fade-Out on Multiple Disjoint Regions holden Pro Tools TDM Systems (Mac) 2 11-30-2007 01:22 PM
Batch fades: Why are fade IN and OUT the same value????????? Jason Rufuss Sewell Pro Tools TDM Systems (Mac) 0 11-18-2007 07:50 PM
How to apply fade-ins and fade-outs on selected regions? Halstein Pro Tools TDM Systems (Mac) 2 05-09-2007 03:07 PM
Fade in and Fade out on multiple regions? bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-03-2006 11:07 AM
fades on muted regions render active fades?! yikes clarpark Pro Tools TDM Systems (Mac) 11 02-08-2004 04:49 PM
