Old 01-31-2014, 12:25 PM
justinphilip justinphilip is offline
Default SC48 + Aviom A360 Mixers: Drum Channels Dropping Out
We have a SC48 mixer with A-Net output card connected to A16 Pro to the new A360 mixers.
Band members are complaining of audio channels dropping out randomly. Last week, no one was near the board and the issue happened.
I had further conversation with the band and they state it's not dropping completing..drummer described it as "the drums sound full and fat before it drops..then it just thins out"
The main channel that seems to be missing is the Drum Stereo AUX (has toms, snare blended in).
Help? Thanks!
Old 02-04-2014, 07:15 AM
noclevername noclevername is offline
Default Re: SC48 + Aviom A360 Mixers: Drum Channels Dropping Out
I read this a couple of days ago and see there's no response so I'll see if my 2 cents is worth anything.
I wonder if you have boosted the output levels like I do to the Aviom system. All of my direct outs and regular outputs have a +10db boost. So I'm almost certain this causes havoc in the digital domain as we've recorded the output of the Aviom to a DAW and the waveform is pretty much flat and full as if there's a nice limiter built in to the output of the Aviom. What I'm curious about is if the limiter in the new A360 doesn't tolerate this much input/output as the older systems do and instead of just sounding thin and limited, it just plain craps out when it reaches a certain level. I know that my drum auxes in particular run pretty hot so I'm just wondering if you turn down the level of the drums will this go away.
A frequent problem I have with my stage musicians using Aviom is that they don't have the master up loud enough (Gain structure in general is always a issue). They take the thing they want to hear the most and turn that channel up all the way and have the master down at around 11 o'clock or less. It will require some re-mixing and training, but those should be at a minimum of 1 o'clock to get the best output. I can't speak to the A360 as I haven't gotten my hands on one yet but I suspect it is a similar situation.
I'm not saying this is your issue, just throwing out a suggestion.
Brian Webber
First Covenant Church
http://www.firstcov.org
Sacramento, CA
Old 02-04-2014, 07:24 AM
Kristo Kotkas's Avatar
Kristo Kotkas Kristo Kotkas is offline
I would suggest you try to record the output to hear for yourself what is happening.
VENUE FAQ & download links, useful
AVID VENUE ILok driver download
VENUE Plugin DSP usage
My AVID:
  • Room A > HD4Accel PCI-CustoMac / 192D / PTHD10 / 2 x Artist Mix / Artist Control
  • Room B > HD3Accel PCI-CustoMac / 192D / PTHD10 / 2 x Artist Mix
  • Big Live > VENUE Profile 48/24 + 2nd Snake card, IOx, FWx, HDx, PQ Rack, 8 x PQ Controllers
  • Small Live > S3L-32 + Mac Mini - two systems - combined one 64/32 FOH / Mon setup
  • On stage > Pro Tools on laptop with variety of M-Audio boxes
Old 02-04-2014, 05:52 PM
Brian I do have them boosted +12db on the direct output for the aux. :-/
I will turn it down and see.
Kristo..I will record the output from the aux and see what it sounds like.
Rendering 5.1 session to QT video - channels dropping? peter5992 Post - Surround - Video 7 04-08-2013 10:00 AM
64 channels with the SC48 united VENUE Live Sound Systems 2 04-03-2012 07:11 PM
Drum aux for Aviom clipping bcs723 VENUE Live Sound Systems 7 09-11-2009 07:57 PM
ReWire dropping channels scottgreiner Pro Tools TDM Systems (Mac) 0 12-08-2003 01:58 PM
List great analog summing mixers for PT's(16 to 32 channels only) Pat Thrall Pro Tools TDM Systems (Mac) 28 02-25-2003 05:40 PM
