  #231
Old 12-20-2009, 02:36 AM
kirkgale kirkgale is offline
Default Re: Best Systems and Components for Win HD/TDM
Hi 3rd Eye...(thnx for the input)
based on which I reverted to my pre 8.0.3 card order (identical to yours) w/out however the 2nd Accel card in the non-x PCI slot.
and its stable..! HD2 w/ Omnisphere, Strike...
wish I could access some info re that PCI Latency Timer in the Supermicro BIOS (mine currently set @ 64)...will have to test whether increase/decrease helps to get this wonderful stability even w/ that extra card/slot powered up...
kirk
  #232
Old 12-20-2009, 06:43 AM
Third Eye Studios Third Eye Studios is offline
I'm glad it's working stable for you. Too bad it's not stable with all the cards.
I'm not going to be at the studio until tomorrow to verify my the PCI latency timer settings for you. Let me know if you find a setting that works. We'll be shopping for a third card soon.
Third Eye Studios.org
  #233
Old 12-21-2009, 03:53 AM
Hmmm 3rd Eye...
we gotta fix this prob otherwise, how r u gonna be brave 'nuf to buy a 2nd accel card for that Supermicro board...?
I played around w/ diff PCI Latency Timer settings in the BIOS today (from the default? 64 up to 96 and down to 32 but in none of those 3 settings was PT free from a "not responding" error for more than 3 or 4 minutes (e.g., loading or unloading a VI plug will trigger it)...
while as soon as I remove that 3rd card and use only the PCI-x slots, no crashes...
you know, I picked this board back in Feb when 8.0 was new but maybe since then there's 'nother i7 board out there w 3 contiguous PCI-x slots..?
kirk
  #234
Old 12-21-2009, 04:45 AM
searced the web for 30 min and found no 3 pci-x contiguous slot boards for the i7 (although I found 3 contiguous regular pci slot boards for the i7 but not ready to go there yet)...
next step may be to email tech support @ supermicro to inquire what BIOS settings they may recommend in this situation...
kirk
  #235
Old 12-21-2009, 06:18 AM
I know. I wonder what Supermicro would have to say about it. We might just have to stay at HD2. We could at least upgrade to HD Accel, as we're non-Accel right now.
When I did a search for MB's a few weeks ago, the Supermicro was it for PCIX.
Feel free to cantact me via email. DanaSampson [at] Thirdeyestudios [dot] org. If you'd like we could chat off of the forum and post back any solutions.
Dana
  #236
Old 12-22-2009, 08:20 AM
pm mastering studio pm mastering studio is offline
Wink Re: Best Systems and Components for Win HD/TDM
some info on the ASUS P7P55D Mobo :
I7 860 CPU
8GB RAM (Kinstong 1333mhz 4 x 2GB)
Samsung 150 GB VeloRaptor (10.000 rpm) - Boot
Samsung 1TB (Samples and storage)
Samsung 350 GB VeloRaptor (10.000rpm) Recording/projects
Asus EN86000 GT Silence
Installed Windows 7 Ultimatex64
ProTools HD8.03
Massive Pack 7
Waves 7.r4 Mercury + SSL400
NI Komplete 6
BrainWorx Complete
Celemony Editor DNA
BFD2
Superiour Drummer 2
HD3 Accel card
I'm a bit dissepointed with loadtimes (up to 10 minutes). on my QuadZilla it took about the same time to fully load PT (could take about 10 minutes due to waves)
With this mean machine I hoped this would be reduced enormously - unfortunatly it stays the same. It takes loooooooong time until my Waves Mercury plugins are loaded which sometimes make me believe it has crashed.
Even a setup without waves takes up to about 5 minutes.
As soon all is running first impressions are ok. Looks stable. Although it take time to load a plugin into the insert-slot (also the case with previous setup as soon as I swithced to 8.0).
I hope I can find some time tonight to start testing the whole thing on some real recordings.
One thing is great - I now have enormous CPU power !!!! whohooooooooooo
I'll keep y'all posted
PS. Important tip : when using windows 7 U have to disable the user-safety thingy (UserAccountControl) . ProTools always needs to be runned as administrator to work !!!
Philippe
Philippe Meiresonne
(Belgium)
http://www.pm-mastering-studio.com
SYSTEM HDX MAC
ProTools HD 2018.1 | 1HDX Card | MacPro 6 Core 32GB Ram PCIe 512GB TrashCan|Magma Thunderbold EB3T|2x PRE | 96 | 192 I/O | HD I/0 16/16
Midi I/O | D-Command ES +16 fader Pack | Xmon
SYSTEM 02
Mac OS 10.10.x |MacBook Pro | 16GB RAM |Mbox 2 Pro Factory | Rack003+ Factory
  #237
Old 12-26-2009, 06:33 AM
undergroundcubby undergroundcubby is offline
I have a HD3 PCI accel and also want to get up on the i7 spec.
I am about to build a system (having always used HP XW's in the past)
So any thoughts on mobos to use I will investigate and gladly guinea pig it.
Hit me up with suggestions and lets see if we can find a solution (just not prepared to Digi crossgrade for same spec system!)
Cheers
HD 3 Accel PCI
HP XW9300
192 I/O
Midi I/O
  #238
Old 12-26-2009, 07:43 AM
Finding a MB for an i7 with 3 consecutive PCI slots is hard. Digi user "kirkgale" and I are currently both using the Supermicro X8SAX. It runs a HD2 great, but kirkgale is having issues with Pro Tools not responding with his 3rd HD card installed. He's currently working with Supermicro to find a solution.
  #239
Old 12-26-2009, 07:47 AM
I7 860 CPU
ProTools HD8.03
Massive Pack 7
NI Komplete 6
BrainWorx Complete
Celemony Editor DNA
BFD2
Superiour Drummer 2
HD3 Accel card
Philippe
Hi, Any joy with tests on this board yet? The supermicro looks OK and they are a rock solid brand, just interested with HD3 PCI on this, cheers
HD 3 Accel PCI
HP XW9300
192 I/O
Midi I/O
  #240
Old 12-28-2009, 03:48 AM
at the nmoment having some minor issues with Wave plugins (see other threads). Also going to switch the Nvidia for an ATI GPU.
all the rest is working Great ! No issues with HD3 setup
Philippe Meiresonne
(Belgium)
SYSTEM HDX MAC
SYSTEM 02
Are these pc components ok? chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 08-13-2010 11:20 AM
need help with HD components FMR_Crisis Pro Tools TDM Systems (Mac) 9 04-17-2010 05:07 PM
What components lie in the most POWERFUL native PTLE Systems? epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-28-2008 07:18 AM
Will these PC components do the job hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-06-2007 08:22 PM
components rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-19-2001 09:32 AM
