Old 08-08-2005, 11:25 PM
waterbug waterbug is offline
Default SATA Drives
OK PC experts. Does Pro Tools 6.9 support SATA drives connected to Serial ATA IDE connection on the motherboard? Building a new system and just want to make sure it's configured correctly.
Waterbug
Old 08-09-2005, 04:11 AM
bb_aus bb_aus is offline
Default Re: SATA Drives
works fine for me
Old 08-09-2005, 06:57 AM
mkosacek mkosacek is offline
me too
Pro Tools 12.4 (because 12.5 is unusable)
UAD Apollo 16 (v8.6)
Dell Inspiron 660 (i3-3240)
Win10 x64
www.studiodrumtracks.com
www.doubledogrecording.com
Old 08-09-2005, 07:21 AM
Carl Fuehrer's Avatar
Carl Fuehrer Carl Fuehrer is offline
I have 2 of the WD 74Gb Raptors and a Seagate SATA II drive in my system and I will never go back! With the native command queing (NCQ) spec on your host card or mobo (SATA II) you can achieve near 10,000RPN performance fron the 7200RPM drive
Peace,
Carl Fuehrer
Pulsar Audio Lab
Old 08-09-2005, 01:02 PM
digi-mike digi-mike is offline
I have two SATA drives and they work great!
Old 08-09-2005, 02:40 PM
koldbludded koldbludded is offline
Got two SATA's and two standard HD's.
Works great!
Old 08-09-2005, 03:18 PM
crookedtourguy crookedtourguy is offline
Two SATA drives and two IDE ATA-100 drives (one is my native the other is in a tray and is used as a back-up drive), is what I have been using for a while.
However, I, too, am about to change over to one 74 Gb WD Raptor 10K RPM drive to use as my native drive and a 300 Gb Seagate SATA that uses NCQ as my record drive, just like Carl mentioned ... I hear it is the only way to go. I will be going to this set-up around this time next week.
I am also going to use a 200 Gb Maxtor ATA-133 in a mobile rack as my back-up drive (I also back-up onto DVD's ... sure hope the price of dual layer DVD comes down soon though), and the SATA audio/record drive is also in a mobile rack tray. The two SATA drives I mentioned earlier are in trays, too ... they were the original drives in my system.
were humans involved ... if so, I can believe almost anything!
Old 08-10-2005, 12:26 PM
thesteve2 thesteve2 is offline
Has anyone tried SATA with a Digi 001 setup? I'm building a new pc in a few days and trying to figure out which type of hard drive to go with.
Steve
Old 08-10-2005, 03:17 PM
I had the same SATA drives with my DIGI 001 before I went to the 002R.
Win10 x64
Old 08-10-2005, 10:40 PM
Cool. Thanks for the info.
Steve
SATA vs IDE drives with PT 7.4 Mark Peteritas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 06-12-2008 08:42 AM
sata and ide drives mdd0127 Storage Subsystems 1 03-13-2006 10:10 AM
Do SATA Controllers/ PCI Cards/ SATA Drives work.. Jason Robo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-14-2005 07:23 PM
Anyone using SATA Drives? joamoa2 Pro Tools TDM Systems (Win) 5 03-16-2005 07:49 PM
SATA Drives?? ozzymau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-21-2004 04:31 PM
