Old 07-19-2012, 03:09 PM
lcphr3ak lcphr3ak is offline
Default Digi 002 Asio Crashing
Hey guys, wasn't sure where to put this, but figured this place would be the best. I have a digi 002 and a Digimax LT. The digimax lt is hooked up to the digi 002 through an adat lightpipe cable. I installed the latest ASIO driver (90265 70921) and am having a problem. No matter what DAW I use (not protools, but others), the program crashes when trying to configure the asio driver. I can just simply open it and then press OK without changing anything and it'll crash the program out. My goal is to have the 002 sync with the digimax through ADAT. The crash log for every program is the same point to dg002asio.dll, so the "reaper" part can be ignored. Here's the event log:
Faulting application name: reaper.exe, version: 4.2.5.0, time stamp: 0x4fff2dc7
Faulting module name: dg002asio.dll, version: 8.0.4.363, time stamp: 0x4d55bfae
Exception code: 0xc0000005
Fault offset: 0x00003e2d
Faulting process id: 0x814
Faulting application start time: 0x01cd65f8c5a8a8c0
Faulting application path: C:\Program Files\REAPER\reaper.exe
Faulting module path: C:\Program Files\Common Files\Digidesign\DAE\Devices\dg002asio.dll
Report Id: 6e665200-d1ec-11e1-8c66-00236ca20c44
Has anyone run into this before?
Here is my system information:
SiSoftware Sandra
ID
Host Name : MacBookPr
Workgroup : WORKGROUP
Computer
Model : Apple MacBookPro5,1 MacBook Pro
Serial Number : W88443TZ1GK
Chassis : Apple Portable
Mainboard : Apple Mac-F42D86C8
Serial Number : Base Board Serial#
BIOS : Apple MBP51.88Z.007E.B06.1202061253 02/06/12
Total Memory : 2.73GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz (2C 2.39GHz, 3MB L2)
Chipset
Memory Controller : nVidia MCP79 Host Bridge 4x 265MHz (1GHz), 4GB DDR3 SO-DIMM 1GHz
Memory Module(s)
Memory Module : Samsung M471B5673DH1-CF8 2GB DDR3 SO-DIMM PC3-8500S DDR3-1066 (7-7-7-20 4-27-8-4)
Video System
Video Adapter : NVIDIA GeForce 9600M GT (32 SM4.0 1.25GHz, 256MB DDR3 1.58GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
Compute Shader Processor : NVIDIA GeForce 9600M GT (32SP 1.25GHz, 256MB DDR3 1.58GHz 128-bit)
Storage Devices
Hitachi HTS723225L9SA62 (250GB, SATA150, 2.5", 7200rpm, 15MB Cache) : 233GB (C:)
MAT[bleep][bleep][bleep][bleep]ADVD-R UJ-868 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
BOOTCAMP (C:) : 233GB (NTFS) @ Hitachi HTS723225L9SA62 (250GB, SATA150, 2.5", 7200rpm, 15MB Cache)
Optical Drive (D:) : N/A @ MAT[bleep][bleep][bleep][bleep]ADVD-R UJ-868 (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : nVidia GeForce ION/9400M/9100M (MCP79) LPC Bridge
Audio Device : nVidia MCP79 High Definition Audio
Audio Codec : Realtek Semi Realtek 885 High Definition Audio
Disk Controller : nVidia MCP79 Memory Controller
Disk Controller : nVidia MCP79 SATA Controller
USB Controller 1 : nVidia MCP79 OHCI USB 1.1 Controller
USB Controller 2 : nVidia MCP79 EHCI USB 2.0 Controller
USB Controller 3 : nVidia MCP79 OHCI USB 1.1 Controller
USB Controller 4 : nVidia MCP79 EHCI USB 2.0 Controller
FireWire/1394 Controller 1 : Lucent/Agere Systems (Was: AT&T MicroElectronics) FW643 PCI Express1394b Controller (PHY/Link)
SMBus/i2c Controller 1 : nVidia MCP5 SMBus 1
SMBus/i2c Controller 2 : nVidia MCP5 SMBus 2
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Printer : CutePDF Writer (4000x4000, Colour)
Printer : Canon MX860 series Printer (Colour)
Printer : Canon MX860 series FAX (200x200)
Scanners and Cameras
Scanner : WIA Canon MX860 ser_001E8F763A38 (Scanner, USB)
Network Services
Network Adapter : NVIDIA nForce 10/100/1000 Mbps Ethernet (Ethernet)
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Wireless Adapter : Broadcom 802.11n Network Adapter (802.11g (ERP), TKIP, 54Mbps)
Power Management
Battery No 1 : SMPNz951 bq20z951 46.00Wh/3.68Ah
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x86
Windows Experience Index
Current System : 5.4
Old 09-21-2017, 06:36 AM
jackp55 jackp55 is offline
Default Re: Digi 002 Asio Crashing
Hi there, I recognize I'm not posting an answer...and this thread is old... but did you figure out the issue?
I'm loving Reaper, but am hitting the same roadblock you did. You still out there???
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 01:45 PM
Digi ASIO mannikin General Discussion 1 09-05-2004 05:15 PM
Digi 002 ASIO and SX BimDimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-27-2003 05:07 AM
Does Digi 001/002 work with ASIO? beatboy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-29-2002 05:47 AM
Digi and ASIO Mr. Shootz Pro Tools TDM Systems (Mac) 0 10-24-1999 03:46 PM
