Old 04-28-2016, 06:56 AM
midnightrambler midnightrambler is offline
Default Re: "Bounce To Disk" Track is "Lower in Volume"
But it does not explain why there was still a (small) drop in level when the source track was straight up the middle.
Yes it does though, as your signal is still going through the panpot, i.e. your bounce is printing at exactly the same level it is hitting your output bus. Look at the options you have when you're bouncing : Render Pan automation is an option, so it must be taking that into consideration. Try deselecting that option and you'll probably find you end up with a file at the right level.
Old 04-28-2016, 02:37 PM
LSNY LSNY is offline
There was absolutely no automation, panning or otherwise on the the source track.
When I did the Bounce, the source track's pan control was straight up the middle. No automation was written, and in fact automation was turned off.
And the resulting Bounce was STILL lower in volume than the source track, as I described above.
All Faders at unity; No Inserts on the Master Fader!
Old 04-28-2016, 02:39 PM
DESELECT THE "INCLUDE PAN AUTOMATION" OPTION. It doesn't matter if there's actual automation or not.
I don't know how much clearer I can be.
Old 04-28-2016, 02:43 PM
Or, if you like, route your track to an unused mono buss and then bounce, which will remove the panpot from the channel. This will also work.
Old 04-28-2016, 07:31 PM
OK, Midnight. That solved it. The Volumes are now identical. Thank you!
This is really useful to me, and hopefully to others as well.
Here's what threw me: I normally access BTD by: File ---> Bounce To---> Disk.
When you access the Dialogue THAT way, you do not see the "boxes" for: Render Automation Volume / Pan.
However, when you access the BTD Dialogue by control clicking on the Track NAME, then you DO see the same dialogue box, this time with the Volume / Pan choices. This is an easier (and for this reason, better) way to se up the Bounce.
This is some "hidden" stuff.
Thanks again…
  #16
Old 04-29-2016, 01:05 AM
Thanks again…
Ah ok! Glad it's worked out :)
  #17
Old 06-05-2017, 08:19 PM
Music Visions Music Visions is offline
same issue here - even real time bounce is the same 7 dB lower - any solutions?
  #18
Old 06-05-2017, 08:38 PM
Ok - thanks MIDNIGHT RAMBLER - worked, but it would be nice to not have to select a track to bounce a selection only to do this - would be nice if it was a preference !
  #19
Old 06-05-2017, 08:45 PM
Are all of these volume comparisons done in a Pro Tools session? If you are comparing audio in Pro Tools to audio outside of PT(like iTunes, or Windows Media Player), then you could be comparing apples to bananas
Can't change external volume from "T" to "R" in workspace. [SOLVED] take77 Pro Tools 12 0 04-09-2016 04:52 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
After "bounce to disk" volume is low felix922 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-20-2008 10:10 AM
If I "Remove Unused Regions" after "Consolidate", track won't play? el biciclista Pro Tools TDM Systems (Mac) 10 04-02-2003 10:17 AM
