Old 01-26-2016, 12:32 PM
Kahlil_J Kahlil_J is offline
Default "The current playback engine does not support a sample rate of 0kHz"
Hey, this is my first time posting on here.
Since I upgraded to El capitan I have not been able to open anything on pro tools because this keeps showing up and then nothing happens. I can't open the mix window or the arrange window or any sessions. I have tried changing the Playback Engine settings but it won't let me to that, the same pop up comes up.
Could someone pls advice me on what to do.
My version of El capitan in 10.11.1 and for my pro tolls 12 its version 12.4.0.
Thank you in advance,
Kahlil
Old 01-27-2016, 10:04 PM
Led Led is offline
Default Re: "The current playback engine does not support a sample rate of 0kHz"
Have you tried holding down 'n' when you launch PT and checking it hasn't got some whacky device selected instead of your normal one?
"The current playback engine does not support a sample rate of 48 KHz" error when tr eyeshow Pro Tools M-Powered (Win) 19 09-09-2015 10:10 AM
"Current playback engine does not support a sample rate of 48 khz" pribb1 Third Party Interfaces 28 07-01-2015 08:47 AM
"current playback engine doesn't support sample rate" terracestudio Windows 2 04-17-2015 02:37 PM
"The current playback engine does not support a sample rate of 48 KHz" E-Lister Windows 3 02-25-2012 11:54 AM
"The current playback engine does not support a bit rate of 48kHZ" M-powered 8 beasleymusic Pro Tools M-Powered (Win) 1 04-02-2011 03:17 PM
