Old 05-16-2013, 12:56 PM
markus44uk markus44uk is offline
Default 003 Rack supported by Pro Tools HD 11?
So if I am running PT10 with CPTK 2 and 003R interface, will the HD PT 11 upgrade work fine? Is it Native?
Last edited by DigiTechSupt; 05-17-2013 at 09:45 AM. Reason: Moved from CPTK thread for visibility.
Old 05-16-2013, 01:06 PM
ejwells's Avatar
ejwells ejwells is offline
Default Re: CPTK gone in PT11 - Upgrade to PTHD11?
It'll be an HD11/HD10 bundle, and will run either 10 or 11 like regular 10 or 11 with a CPTK.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Old 05-16-2013, 01:11 PM
ejwells's Avatar
Question is whether I can use my existing 003R with PT 11 HD software or am I forced to get a new interface? I also have an original Control 24 and I know its not officially supported but fingers crossed it will still work. $600 is a lot to spend to find out afterwards...
The 003 is supported for use with PT11, so you'll be fine there.
I have no idea about the Control 24
Sent from my SCH-I510 using Tapatalk 2
Old 05-16-2013, 01:12 PM
Drew Mazurek's Avatar
No, the HD iLok asset simply "unlocks" features in the software. You will be fine.
www.drewmazurek.com
Old 05-17-2013, 09:55 AM
DigiTechSupt's Avatar
Default Re: 003 Rack supported by Pro Tools HD 11?
The 003 Rack is currently listed as a supported interface in the prelimenary Pro Tools 11 and Pro Tools HD 11 docs.
-jeff
Avid Audio Tech Support
Support FAQ
Will Pro Tools 10 be supported in Mavericks? slfinne82 Pro Tools 10 93 04-03-2014 01:58 AM
Mavericks Pro Tools 11 IMAC27 Not Supported? sessionguitarist2013 Pro Tools 11 11 11-05-2013 11:33 AM
Eleven Rack & Pro Tools 11 - Supported? acmost Eleven Rack 117 09-29-2013 05:48 PM
Grm tools crashes...still supported? dj_grimmace Pro Tools TDM Systems (Mac) 3 02-28-2011 12:10 PM
" * 192k not supported with Pro Tools LE" birdFEEDER 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-07-2005 04:13 PM
