Working with 24FPS
Hi
I am sound designing and mixing a cartoon made at 24 FPS Standard Defintion. I have Virtual VTR and a Kona LHe card on a second machine. I am having trouble with sync. I have set Pro Tools to 24FPS, and VVTR is receiving 24, but the sync is drifting. The SYNC I/O and the Kona card are locked to blackburst . What I have been told is I need to be working at 23.98 with a Trilevel Sync, either with VVTR Pro using pull-down, or converting the video file with Cinema Tools (which I have but have never used). This is the first time I have worked at 24 FPS. The Kona card does not support Standard Def at 24 FPS, which I guess is not typical. Can anyone give me some recommendations on how to make this work with proper sync? |
Re: Working with 24FPS
hi there.
i have a setup just like that. your issue is that your MONITOR will not play true 24 fps. simply switch Pro Tools to 23.976 and engage .1% pull down. when you deliver files, remember to disengage pulldown so they can line it up with their 24fps timeline.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Interesting... but do I need VVTR Pro? A trilevel sync?
no and no.
what i do is pop the 24 FPS movie into Final Cut and transcode it to a 23.976 movie -- usually DVCPRO 50 -- so that i can match it. that movie goes in VVTR, then my PT is set to 23.976 and pulldown. i did a whole animated feature like this and am doing a live-action feature like this. pull of the pull, print the mix at straight 48 and send to the editor.
Thanks for these responses. So is no one using the Pro VVTR, or Trilevel sync? Will VVTR just receive the 23.98 from pro tools and be cool?
well...
i use tri-level, but you CAN get by without it as i did for a while. i never had a sync issue. VVTR Pro has a lot of features, but it is not MORE compatible with 23.976.... plain VVTR is just fine with 23.976 and HD codecs. (there is a .1% pulldown of the video capability in VVTR) the PRO add things like graphic overlay for TC and streamers...
That did it, thanks!
This might be a silly question but since now more or less all screens, projectors, QT-cards are multi-format wouldn´t it be an option for people in the NTSC-world to simply set your QT-card to PAL and simply output all video from 24fps QT to PAL-video wich wil automatically playback with an additional double-frame per second so you will see your 24fps QT on a video-screen running with correct timing. No transcoding necessary. And most importantly NO PULLDOWN!
just a thought, frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
interesting idea, Frank. problem is, many of the TV's and monitors available in America 'freak out!' when they get a PAL signal. They need to lock to some kind of NTSC feed.
-Richard
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5 www.TakomaMedia.com |
Using 25fps to 24fps then the converted 24fps to new 25fps. Stay with me on this! | abes | Post - Surround - Video | 2 | 03-01-2013 09:36 AM |
REVISITED - Working with 24FPS | Bokir | Post - Surround - Video | 7 | 04-27-2007 09:59 AM |
OMF at 24fps | baylonfonseca | Tips & Tricks | 2 | 08-14-2005 05:29 AM |
OMF at 24fps | baylonfonseca | Post - Surround - Video | 7 | 08-07-2005 10:07 AM |
Working with a 24fps film | Spin Girl | Post - Surround - Video | 5 | 05-01-2004 11:51 PM |
