Command 8 working with 2018?
Hey so my command 8 worked immediately when I first got it and was using PT12. I upgraded to 2018 with the exact same setup and now it stays offline no matter what I try (selecting/unselecting in peripherals, using different midi channels, restarting, re downloading and installing drivers from the avid site, I even tried hooking it up with a midi/usb interface connecting the command 8 with MIDI in/out and a motu into my mac via usb....)
Mac Pro 3.46GHz Westmere 6-Core 32GB sierra os 10.12 |
No drivers for C|8 necessary
You should trash prefs and try again. Does the system go into utility mode? Does all the fader cal, etcétera? I would plug the system up via USB directly to the MP. Also try to change the USB port on the MP to see if that’s an issue I would also try an install an old version of 12, and see if that makes a difference
Re: Command 8 working with 2018?
Did you changed or added something after you’ve upgraded ? Another control surface? Keyboard ? C|8 doesn’t like sharing :)
WIP house Prod - home studio iMAC - Pro Tools Ultimate 2022.6 - RME Digiface USB - Audient iD22 - Behringer ADA8200 - Digidesign C|8 - NI KK A61 STUDIO PRO Post-prod MAC Pro "Trash can" - Pro Tools HDX + Ultimate 2021.12/Avid C|24/S3/ProTools|Dock. Blackmagic. |
Command 8 work with high sierra and 2018.xx? | analog orange | ProControl, Control|24, Command|8 | 6 | 05-12-2019 05:41 PM |
Command 8 - Meters Not Showing in 2018.7 | Siegfried Meier | Pro Tools 2018 | 7 | 03-16-2019 10:12 AM |
August 2018 - a day is coming D-Command ES | mgoorevich | ICON & C|24 | 9 | 08-23-2018 04:11 PM |
PT 2018:1 - video engine not working (for some) | noiseboyuk | Pro Tools 2018 | 13 | 04-05-2018 08:21 PM |
Track preset key command PT 2018 | tomdiek | Tips & Tricks | 1 | 03-03-2018 11:52 AM |
