Old 06-01-2003, 10:48 AM
d_matt d_matt is offline
Default How to select all tracks in the edit window
Looked through the manual but can't find out how to do this. How do I select all tracks over a specific range in the edit window?
Thanks,
-Matt
002, PTLE 5.3.2, A7V266-C, XP2100+ (1.7GHz), XP Home
Old 06-01-2003, 11:02 AM
Rabidium Rabidium is offline
Default Re: How to select all tracks in the edit window
there's a pre-created group called 'all' just click that, then highlight the area you want.
To find edit groups, click that double arrow in the bottom left corner of the edit window.
And create some groups for the tracks you already have, you'll find it immensely helpful and easy to do. say a vocals group so you can mute all the vocals in one swoop, or a percussion group so you can lower the levels of all the percussion at once. (Start+click the name of the group to show/hide tracks) You can also create seperate mix groups, look for the same double arrow in the mix pane.
-Olaf
Always more than you wanted to know.
I guess I'm back.
www.byOlaf.com
Old 06-01-2003, 11:05 AM
froyo froyo is offline
Hello. If you select an area on a timeline it will select across all tracks. If you double click on a timeline it will select all tracks in the entire session. What manual are you referring to? Because this info, and everything else you want to know about Pro Tools, is in the Pro Tools Reference Guide.
froyo
Old 06-01-2003, 01:04 PM
Hey Froyo,
Tried that, doesn't work.
Old 06-01-2003, 01:32 PM
Hello. D_matt you tried which one?
First off, make sure the "Link Edit and Timeline Selection" button is active. It's that button next to the 1,2,3,4 and 5 zoom memory numbers in the Edit Window, top left. Right under the Grid button. Make sure that's lit up. Another way is to check under the Operations drop down menu. There is a command called Link Edit and Timeline Selection. Make sure there is a check mark to the left indicating it is active. Another way is to try the shortcut 'Shift + /'.
Once you make sure that's active then you can try either one. Selecting an area in a timeline or double clicking. I hope this helps.
P.S. Pro Tools Reference Guide. Everything you always wanted to know.
froyo
Old 06-01-2003, 01:44 PM
Ah, ok,
It was b/c I didn't have edit and timeline linked.
Couldn't figure that out for a while.
-Matt
Old 06-02-2003, 12:43 AM
Oh, hey, nice tip, I never noticed that.
I love how in this program there's always a few ways to do any one thing.
-Olaf
I guess I'm back.
www.byOlaf.com
Old 03-06-2021, 08:49 PM
federico federico is offline
-Olaf
HI, what If I already selected a region on a track and I want to select that region in all tracks, without moving the selection?
Old 03-06-2021, 08:53 PM
I found a partial solution. If you do that and then select another track's name with alt+shift on Win it will select all tracks. However alternate playlists are not selected. Is there a shortcut to include them as well?
Thanks.
Old 03-06-2021, 10:53 PM
HurtMesaMusic's Avatar
HurtMesaMusic HurtMesaMusic is offline
Hold shift, type p and/or ; until they’re all selected.
Select in Region bin won't select region in edit window? innerbooty Pro Tools TDM Systems (Mac) 3 03-24-2013 11:04 AM
Is there a way to automatically bring a track you select into view in the edit window Focuret Artist Series 4 01-05-2013 01:48 PM
Selecting in regions list doesn't select in edit window peytontodd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-15-2011 02:33 PM
Can I hide tracks in Edit window but not in Mix window? Avi Bortnick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-07-2010 06:31 AM
Losing ability to select clips in Edit window kheftel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-06-2009 12:23 PM
