Old 10-18-1999, 03:58 AM
Guest
Posts: n/a
Default One Lynx or two vicar?
Whenever I hear the word Lynx mentioned it's always as a pair....Do you need two to get a 2'' tape to chase PT or one? Whats the deal? They make a new one, does this do the job of two now, all in one?
Thanks in advance
Jules
Old 10-18-1999, 04:15 AM
Disco_Doctor Disco_Doctor is offline
Default Re: One Lynx or two vicar?
You'll only need one in your case. You need one Lynx for every machine that needs machine control. PT doesn't need machine control - it just locks to SMPTE and releases to clock (you're slaving the 2" and Pro Tools to video, right Jules?)
On the other hand, you could go with a Microlynx. I'm not an expert with the Microlynx, but my understanding is that you add cards to it to control multiple transports simultaneously - a video deck, a 2" machine, and Pro Tools could all be locked and controlled with one Microlynx.
Old 10-18-1999, 08:27 AM
Silver Surfer Silver Surfer is offline
A stock Microlynx provides control for two machines. A third machine can be controlled with the addition of an optional card. If you need clock distribution, another card for the ACG slot is needed. It even sends and receives MTC. However the Microlynx does not communicate with the Digi Serial Port.
Old 10-18-1999, 01:57 PM
F.J. F.J. is offline
Jules,
If all you have to do is lock 2" tape to PT's then you dont even need a Lynx. All you have to do is stripe SMPTE on one of the tracks on the 2" and PT's will lock to that. If however you are looking for a master control module for your studio I would recommend a MicroLynx. As said before it comes standard with control for 2 machines (VTR's, ATR's etc.) and it generates MTC and you can get the optional 3rd card if you expand later on. It also has the optional ACG card so it can act as the master clock source for your studio.
Good Luck!
Old 10-18-1999, 01:58 PM
Jules,
Good Luck!
Old 10-18-1999, 02:18 PM
Guest
Posts: n/a
Thanks guys. I want 2" to chase PT for better sound into PT than vice versa. I don't need extencive machine control - just a "dump all tracks into PT in one pass" function.
I want to move towards a house ext clock source like an Aardsync device.
Will the Microlinx work well with that?
thanks
Jules
Needing more I/O...Lynx?? rcd Pro Tools TDM Systems (Win) 2 10-02-2012 04:15 PM
FT: Lynx LT-HD for LT-USB acmost Buy & Sell 2 07-16-2012 03:49 AM
Anyone use Lynx Aurora's with PT9? LanceK macOS 8 03-02-2012 06:45 AM
Anyone using a Lynx Aurora 16 with PT9? deskman Pro Tools 9 9 12-10-2010 09:51 PM
lynx aurora pie55 Pro Tools TDM Systems (Win) 4 12-30-2009 02:19 AM
