Old 03-18-2017, 07:35 AM
Cryos's Avatar
Cryos Cryos is offline
Default Dock Jog Wheel
here's small issue I've come across and am wondering if this can be addressed in the next Eucon update.
On every single AVID controller interface (excluding Eucon based controllers as far as I'm aware) that have a Jog Wheel....holding the "control key" on the keyboard and then moving the Jog wheel makes it engage....Not so with the Doc Jog Wheel. I have to literally hit the Jog switch... it's not the end of the world but it is an annoyance to have to do this... Reason being: when editing in protools if you hold "control" and move the mouse you can scrub...
In my mind I think this should have the same behavior with the Doc.
cheers
Sent from my SM-G935W8 using Tapatalk
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 03-19-2017, 08:54 PM
Anthony_Anz Anthony_Anz is offline
Default Re: Dock Jog Wheel
cheers
agreed!. Jog should stay engaged after any transport key is pressed.
Not sure if this will help you but my work around is to use Move/Sel instead of Jog. I actually prefer this over jog because you can move along the timeline based on your nudge values (stay locked to the grid) AND it will not disengage when you hit any of the transport buttons.
Old 02-17-2020, 11:47 AM
XJENSEN XJENSEN is offline
Does anyone know the reason why the Jog mode doesn't stay engaged after pressing any transport button?
Suggestion: Users of S3&Dock together: dock fader becomes 5th VCA master fader bassmagnetic Avid S1, S3, Dock and Control App 0 10-01-2016 08:20 AM
OWC's TB2 dock YYR123 General Discussion 3 11-19-2014 06:39 AM
Scrub Wheel or Jog Wheel for PT JaredC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-07-2004 06:01 PM
T20 dock??? babilonburning 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-18-2000 03:01 PM
