glitch in sound when adjusting plugins
is it normal for there to be a glitch in the audio when adjusting plugins.Check out what I mean in this video toward the middle of the video as he is adjusting the plugin and the sound warps a little bit,.This seems to happen to me sometimes when I'm adjusting or turning plugins on .Not sure when exactly it happens to me but it sounds like this.
https://www.youtube.com/watch?v=JHf2e9pkKwM |
Re: glitch in sound when adjusting plugins
I don't recall ever hearing audio glitches while adjusting any plugin. Tough to offer any advice with zero details about your system or what plugins are causing it.
oh no kidding .I'm not sure when exactly it happens>Ill have to keep an eye on it.Ill post a Sandra so you can checkout my system
here's Sandra
ID
Host Name : Mike-PC Workgroup : WORKGROUP Computer Model : OEM System Product Name Serial Number : System Ser********** Chassis : Desktop Mainboard : ASUS P6X58D-E Serial Number : MT70090******** BIOS : AMI (OEM) 0701 05/10/2011 Total Memory : 12GB DIMM DDR3 Processors Processor : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (4C 8T 2.81GHz/3GHz, 3.22GHz IMC, 4x 256kB L2, 8MB L3) Socket/Slot : FC LGA1366 Chipset Memory Controller : ASUS X58 I/O Hub 2x 3.22GHz (6.43GHz) Memory Controller : Intel Core Desktop (Bloomfield) UnCore 2x 3.22GHz (6.43GHz), 3x 4GB DIMM DDR3 1.61GHz 192-bit Memory Module(s) Memory Module : SanMax ModulePartNumber00 2GB Memory Module : SanMax ModulePartNumber01 2GB Memory Module : SanMax ModulePartNumber02 2GB Memory Module : SanMax ModulePartNumber03 2GB Memory Module : SanMax ModulePartNumber04 2GB Memory Module : SanMax ModulePartNumber05 2GB Video System Monitor/Panel : (Standard monitor types) Generic Non-PnP Monitor Monitor/Panel : ACR S271HL (1920x1080, 27.2") Video Adapter : NVIDIA GeForce 210 (2CU 16SP SM4.1 1.4GHz, 1GB DDR3 1.2GHz 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 1GB DDR3 1.2GHz 128-bit) Compute Shader Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 1GB DDR3 1.2GHz 128-bit) CUDA GP Processor : NVIDIA GeForce 210 (16SP 2C 1.4GHz, 1GB DDR3 1.2GHz 64-bit) Storage Devices WDC WD10EALX-229BA1 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 932GB (C:) WDC WD10EALX-229BA1 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 932GB (D:) WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 932GB (E:) WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 932GB (G:) ASUS DRW-24B1ST a (SATA, DVD+-RW, CD-RW) : N/A (F:) Logical Storage Devices System Reserved : 100MB (NTFS) New Songs (D:) : 932GB (NTFS) @ WDC WD10EALX-229BA1 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) Old Songs (E:) : 932GB (NTFS) @ WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) Backups (G:) : 932GB (NTFS) @ WDC WD10EALX-009BA0 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) Main Drive (C:) : 931GB (NTFS) @ WDC WD10EALX-229BA1 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) Optical Drive (F:) : N/A @ ASUS DRW-24B1ST a (SATA, DVD+-RW, CD-RW) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : ASUS High Definition Audio Controller Audio Codec : nVidia 000B Audio Codec : nVidia 000B Audio Codec : nVidia 000B Disk Controller : ASUS 6 port SATA AHCI Controller Disk Controller : ASUS 88SE9123 SATA-600 Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS VIA VT6308 1394 OHCI Controller SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Marvell Yukon 88E8056 PCI-E Gigabit Ethernet Controller (Ethernet, 100Mbps) Power Management Battery No 1 : CPS UPS CP825 Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.5 |
I didn't watch the video, but I have experienced this for years generally with Waves reverbs and delays. Happens on my PC Nuendo rig, and happens with reverbs and delays in Pro Tools. It's nothing that I've ever been concerned about, always chalked it up to the fact that I may be making changes to big verbs or long delays.
I would occasionally crash the PC but only in the final stages when there were a lot of plug ins loaded. Remember, these are computers that are doing a great deal of calculations. When you try to change certain settings in real time there may be artifacts depending on the system. I vaguely remember even an analogue Klark-technic reverb I used to love would do things like this if I changed certain patches. Don't sweat the small stuff. I mean if it's happening for automation then you have a problem.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording @FBRrecording - Instagram Rig MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors |
2 things to think about;
This is confusing to me from the Sandra report... Memory Controller : ASUS X58 I/O Hub 2x 3.22GHz (6.43GHz) Memory Controller : Intel Core Desktop (Bloomfield) UnCore 2x 3.22GHz (6.43GHz), 3x 4GB DIMM DDR3 1.61GHz 192-bit Memory Module(s) Memory Module : SanMax ModulePartNumber00 2GB Memory Module : SanMax ModulePartNumber01 2GB Memory Module : SanMax ModulePartNumber02 2GB Memory Module : SanMax ModulePartNumber03 2GB Memory Module : SanMax ModulePartNumber04 2GB Memory Module : SanMax ModulePartNumber05 2GB I don't get why it says 3x4, but then shows 6 RAM modules. Are they all identical? Are RAM timings set manually in BIOS or are you using the DEFAULT setting? #2-what interface are you using and are you recording to a FW drive? VIA FW controllers are usually not PT-compatible.
thanks Dr.
Albee I'm not sure about how the computer is set up to answer those questions but I am recording to the WDC WD10EALX-229BA1 (1TB, SATA600, 3.5", 7200rpm, 32MB Cache) : 932GB (D:) I am using a Lynx Aes16e card for an interface I just had the machine setup so I was not recording on the C drive and I have not had any freezes since then.It seems to work good now other than those sound glitches once and a while |
Albee, I have noticed some odd things using Sandra. It shows my eight 2gb memory modules as eight 1gb modules.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
This is one of their BLUE drives and I would NOT use it for recording. My friend's rig(with 3 WD BLUE drives) had lots of issues, and once he moved sessions OFF those drives, the issues cleared up. He also had to return 2 for replacement under warranty. The BLUE drives are like the McDonalds of hard drives(built cheap for general use). The WD GREEN drives are built to save power by sacrificing performance(NOT what you want in any audio machine). The BLACK drives are built for best performance and longest life, and those are the only WD drives to buy. I own a few BLUE drives and only use them as system drives(with plenty of backup) or in external drive cases as backup drives
Adjusting several plugins together. | Audioartist | Pro Tools TDM Systems (Mac) | 2 | 02-11-2012 10:03 AM |
rare random glitch sound | S.TaylorRCC | Windows | 3 | 09-19-2011 11:53 AM |
11 Rack ON/OFF Sound Glitch 2 | ontheroad | Eleven Rack | 2 | 11-27-2010 01:35 AM |
11 Rack ON/OFF Sound Glitch | ontheroad | Eleven Rack | 15 | 10-01-2010 06:15 AM |
Sound glitch(?) in PT8 | CamM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-29-2009 01:37 PM |
