Old 10-26-2011, 09:35 AM
migu migu is offline
Default Pro Tools 10 - Inputs inactive
Hello
I just upgraded my PT9 to PT10.
When I work with it everything plays back as before. No problems.
But when PT is opening I get the message
Your I/O setupt has changed since the last time this session was saved.
See the I/O Setups window to see what's changed
Some paths were made inactive because they could not be assigned to existing path definitions.
When I then go to the mixing window all my Input choices are grey/notactive.
I can activate them by clicking and then chossing the input. But this is kinda annoying....
Anyone knows going on??
I'm using a MBox Mini 3
Migu
Old 10-26-2011, 10:51 AM
H-Musikk H-Musikk is offline
Default Re: Pro Tools 10 - Inputs inactive
My input (and output) changed name after the update. On PT9 they were named "In 1" "In 2" etc. But when I installed PT 10 they were named "Lynx Recording Input 1" "Lynx Recording Input 2" (or somethin like that) I just renamed them to the name they had in PT9 and everything was OK again
Regards
www.h-musikk.no/english.html
Norway
ASUS X99-E, Intel Core i7-6850K, Noctua NH-U9S, Corsair Vengeance LPX DDR4 2133MHz 16GB, Samsung 960 EVO 250GB M.2 PCIe SSD (System), Samsung 850 EVO 500GB 2.5" SSD (Data), Samsung 850 EVO 1TB 2.5" SSD (Sample), WD Desktop Black 1TB 3.5" (Audio), Gigabyte GeForce GTX 1060, Corsair RM750x 750W, Samsung 34" LED Curved, Windows 10 Pro 64-bit, Lynx AES16e, Aurora 16, Cakewalk by BandLab, Pro Tools 2021
Old 10-26-2011, 11:12 AM
Ok, thanks! seems to have solved the problem.
Another question:
When I try to save the project with CTRL+S, a pop-up always keeps coming up saying "save as".
Is this a bug? Does anyone have the same problem?
Old 10-26-2011, 11:17 AM
PT10 has a new file format. So the first time you try to save it will ask that question. Just press OK and save. The next time you hit Ctrl +S it wil just save as normal...
Regards
Norway
Old 10-26-2011, 11:22 AM
Yes, but that's exactly my problem.
The first time I saw it was a new file format and it was ok. But now everytime I save the file it keeps asking "save as", athough I already created a .ptx file.
Old 10-26-2011, 11:31 AM
OK,,,strange...it didn't do that on my system....
Regards
Norway
Old 10-26-2011, 12:00 PM
yes it is quite strange.
maybe somebody can clarify if this is a bug or not
Old 10-26-2011, 11:25 PM
in your i/o settings is an option called "current session overwrites settings" or something similar. you should check this box to resolve your problem. it should be checked by default but is not. also, once you have your i/o settings how you want them, saving it and putting it in a safe spot in order to use it as an import option is a huge time (and stress) saver
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 10-29-2011, 08:21 AM
Thanks but it still doesn't work.
Everytime I want to save my project (CRTL+S), pro tools always wants to save it as another file (Save as).
This is extremely annoying.....
Anyone has anyother ideas???
Migu
REASON 7 inactive in PRO TOOLS 11- AAE error -20010 blue32 macOS 1 07-13-2013 09:29 AM
Pro tools 10.1 I open session tracks wont play says output map is currently inactive shamanrock Windows 16 01-23-2013 06:22 PM
Inactive Inputs help please! qej macOS 4 11-11-2012 03:09 PM
Can't Remove Inactive Inputs jblass macOS 3 12-30-2011 02:36 PM
soft samplecell rendered "inactive" when loading pro tools LE 5.1.1 Charles Aarons Digidesign Hardware & Software 0 04-20-2003 11:54 AM
