digi003 factory win7 64 bit freezes or blue screen
Hi
I need help... my pt 8.0.4 always freezes when opening session or clossing session even during session please help SiSoftware Sandra System Host Name : DAW User : HK Workgroup : WORKGROUP Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.67GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 2x 256kB, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, Synchronous, ATC, 16-way, 64 byte line size, 16 threads sharing System System : MSI MS-7522 Mainboard : MSI MSI X58 PLATINUM SLI(MS-7522) Bus(es) : ISA PCI PCIe USB FireWire/1394 Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : No System BIOS : American Megatrends Inc. 8.15 Total Memory : 11.99GB Chipset 1 Model : MSI ??? (3405) Front Side Bus Speed : 1x 133MHz (133MHz) Video System Monitor/Panel : Acer X223W Monitor/Panel : ACR X193W+ Adapter : ATI Radeon HD 4800 Series Physical Storage Devices WDC WD6400AAKS-22A7B0 3.5" 640GB (SATA300, 7200rpm, NCQ, 16MB Cache) : 596.17GB (E:) ST3500320AS 500GB (SATA150, NCQ) : 465.76GB (D:) WDC WD3000HLFS-01G6U0 300GB (SATA300, 10000rpm, NCQ, 16MB Cache) : 279.46GB (C:) HL-DT-ST DVD-RAM GH22NS30 (SATA150, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache, 192kB Flash) : N/A (F:) ELBY CLONEDRIVE (SCSI, SCSI-2, 256kB Cache) : N/A (G:) Logical Storage Devices Audio (E:) : 596.17GB (408.08GB, 68% Free Space) (NTFS) @ WDC WD6400AAKS-22A7B0 3.5" 640GB (SATA300, 7200rpm, NCQ, 16MB Cache) Back Up (D:) : 465.75GB (445.53GB, 96% Free Space) (NTFS) @ ST3500320AS 500GB (SATA150, NCQ) DAW (C:) : 279.46GB (144.21GB, 52% Free Space) (NTFS) @ WDC WD3000HLFS-01G6U0 300GB (SATA300, 10000rpm, NCQ, 16MB Cache) CD-ROM/DVD (F:) : N/A @ HL-DT-ST DVD-RAM GH22NS30 (SATA150, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache, 192kB Flash) CD-ROM/DVD (G:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, 256kB Cache) Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Intel(R) ICH10 Family USB Universal Host Controller - 3A34 USB Controller/Hub : Intel(R) ICH10 Family USB Universal Host Controller - 3A35 USB Controller/Hub : Intel(R) ICH10 Family USB Universal Host Controller - 3A36 USB Controller/Hub : Intel(R) ICH10 Family USB Universal Host Controller - 3A37 USB Controller/Hub : Intel(R) ICH10 Family USB Universal Host Controller - 3A38 USB Controller/Hub : Intel(R) ICH10 Family USB Universal Host Controller - 3A39 USB Controller/Hub : Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A USB Controller/Hub : Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Composite Device USB Controller/Hub : Maschine Controller USB Controller/Hub : Kore 2 Controller FireWire/1394 Controller/Hub : Texas Instruments 1394 OHCI Compliant Host Controller FireWire/1394 Controller/Hub : 1394 OHCI Compliant Host Controller Keyboard : Standard PS/2 Keyboard Mouse : Microsoft PS/2 Mouse Printers and Faxes Model : Microsoft XPS Document Writer Model : Fax Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows Vista Business Media Center 6.01.7600 Platform Compliance : Win64 x64 Windows Experience Index Current System : 5.9 Network Services Adapter : Realtek PCIe GBE Family Controller #2 Adapter : Realtek PCIe GBE Family Controller |
Re: digi003 factory win7 64 bit freezes or blue screen
Operating System(s)
Windows System : Microsoft Windows Vista Business Media Center 6.01.7600 Platform Compliance : Win64 x64 Vista 64 bit is not supported. Try again with Windows 7 Ultimate 64 bit.
hm... interesting... I am using win 7 ulitimate 64 bit but sandra report shows that i am using vista... whats up with that?
check your mobo BIOS. probably old...and try different F/W drivers also.
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
i am using the siig approved fw card but should i just use the on board fw ?
also i 'think' the reason your system is not readin' your OS properly is 'cause of your mobo BIOS rev. another DUCer just had a similiar problem and updatin' his bios corrected the problem. do some research on the MSI website
sorry i was using old version of sandra report i downloaded the newer version and it shows the correct os here it is
SiSoftware Sandra Computer Model : MSI MS-7522 Workgroup : WORKGROUP Host Name : DAW User : HK Processor Model : Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed : 2.8GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 8MB, ECC, Synchronous, ATC, 16-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : MSI MSI X58 PLATINUM SLI(MS-7522) BIOS : AMI V3.6 07/14/2009 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 12GB DIMM DDR3 Chipset Model : MSI X58 I/O Hub Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Chipset Model : Intel Core Desktop (Bloomfield) UnCore Front Side Bus Speed : 2x 2.41GHz (4.82GHz) Total Memory : 12GB DIMM DDR3 Memory Bus Speed : 2x 536MHz (1GHz) Memory Module(s) Memory Module : OCZ OCZ3P1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3P1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3P1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3P1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3P1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module : OCZ OCZ3P1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Video System Video Adapter : ATI Radeon HD 4800 Series (800 SM4.1 625MHz, 512MB DDR3 2x993MHz, PCIe 2.00 x16) Video Adapter : ATI Radeon HD 4800 Series (800 SM4.1 625MHz, 512MB DDR3 2x993MHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 4800 Series (800SP 625MHz) Storage Devices WDC WD6400AAKS-22A7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 596GB (E:) Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) : 466GB (D:) WDC WD3000HLFS-01G6U0 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) : 279GB (C:) HL-DT-ST DVD-RAM GH22NS30 (ATAPI, DVD+-RW, CD-RW, 2MB Cache) : N/A (F:) ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) : N/A (G:) Logical Storage Devices Audio (E:) : 596GB (NTFS) @ WDC WD6400AAKS-22A7B0 (640.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Back Up (D:) : 466GB (NTFS) @ Seagate ST3500320AS (500.1GB, SATA150, 3.5", 7200rpm, NCQ) DAW (C:) : 279GB (NTFS) @ WDC WD3000HLFS-01G6U0 (300GB, SATA300, 3.5", 10000rpm, NCQ, 16MB Cache) Optical Drive (F:) : N/A @ HL-DT-ST DVD-RAM GH22NS30 (ATAPI, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (G:) : N/A @ ELBY CLONEDRIVE (SCSI, SCSI-2, BD-R, HD-DVD-R, DVD-R, CD-R, 256kB Cache) Peripherals LPC Hub Controller 1 : MSI LPC Interface Controller LPC Legacy Controller 1 : Fintek F71882FG/F71883FG Audio Device : MSI HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Audio Device : Hightech Information System HD48x0 audio Audio Codec : ATI (AMD) AA01h Serial Port(s) : 1 Disk Controller : MSI 4 port SATA IDE Controller Disk Controller : MSI 2 port SATA IDE Controller Disk Controller : MSI JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : MSI USB UHCI Controller #4 USB Controller 2 : MSI USB UHCI Controller #5 USB Controller 3 : MSI USB UHCI Controller #6 USB Controller 4 : MSI USB EHCI Controller #2 USB Controller 5 : MSI USB UHCI Controller #1 USB Controller 6 : MSI USB UHCI Controller #2 USB Controller 7 : MSI USB UHCI Controller #3 USB Controller 8 : MSI USB EHCI Controller #1 FireWire/1394 Controller 1 : Avlab Technology XIO2200(A) IEEE-1394a-2000 Controller (PHY/Link) SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe GBE Family Controller Network Adapter : Realtek PCIe GBE Family Controller #2 Wireless Adapter 1 : 802.11 USB Wireless LAN Card (802.11g (ERP), WEP n-bit, 270Mbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7600 Platform Compliance : x64 Windows Experience Index Current System : 5.9 |
thank you for your help ....
and there are three drivers to choose from 1394 ohci compliant host controller 1394 ohci compliant host controller (legacy) texas instruments 1394 ohci compliant host controller which one should i chooose? thanks |
update...
i tried all three with same result... please help |
Have you updated the PACE drivers from www.paceap.com?
Could you please post a list of plug-ins and other software installed? (Please include version numbers.)
PT 11&10 w/PC Laptop (win7) & DIGI003 Which ones? | sharpo07 | Pro Tools 11 | 0 | 11-07-2013 10:35 AM |
Random freezes using Pro Tools 9 on new Macbook running Lion OS (blue screen editing) | pabloprieto2002 | Pro Tools 9 | 9 | 08-11-2012 06:40 AM |
PT 8.0.3 + P6TD Deluxe + Intel i7 + Win7 64bit - Blue Screen (Solved). | Hemophagus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-09-2010 09:08 AM |
Pro Tools LE 8.0.3 + Digi003 freezes with Win7 Pro x64 | Chief Pronto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 53 | 01-10-2010 10:42 AM |
Help!! Constant SCREEN FREEZES and Out of the Blue SYSTEM REBOOTS ITSELF! | asher400 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-07-2003 10:15 AM |
