Old 10-23-2007, 07:23 PM
saki saki is offline
Default bounce question
Hi All.
I'm new to Pro Tools. I've got a 5.1 session happening and I can bounce it out as a 5.1 split or interleaved file no problem.
What I'm wondering is how can I bounce a stereo version?
I'm looking through the manual and I'm not having alot of luck.
To simplify the issue, I opened a new 5.1 session (DTS format), created a 5.1 track and imported the 5.1 bounce I created from the original session. So now I have a simple session with one track containing a 5.1 mix. But when I 'bounce to disk' I don't get the option to bounce it down in stereo.
Any help will be much appreciated.
Saki
Old 10-23-2007, 07:32 PM
BaileyBass BaileyBass is offline
Default Re: bounce question
interleaved is stereo... that is what you need.
Old 10-23-2007, 07:44 PM
JKD99 JKD99 is offline
Hi Saki,
You can't bounce to Stereo from 5.1, you have to manually do a folddown. The various formulas for doing the folddown have been discussed and debated on the Post and Surround forum for quite awhile, so you can do a search and get a lot of different opinions.
Usually, though, you'd split your 5.1 track out to 6 mono tracks, then pan them accordingly to a stereo output for bouncing or to a stereo buss to do a Record To Disk (the preferred method, IMHO).Left and Right go to L&R as-is, Center panned Center and lowered 3db (or not lowered at all, depending on your opinion), Surrounds Panned and lowered 6 db (or to taste) and LFE either completely unused or lowered 9-10db depending on what's actually IN the LFE channel.
If you RTD instead of bounce, you'll get a Split Stereo file, which would then need to be Exported ("Export Regions As Files" in the Region Bin menu, or there's a key command for it that escapes me at the moment) if you require a Stereo Interleaved file.
Hope this helps, good luck!
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 10-24-2007, 02:17 AM
Unfortunately that is not the case.
The interleaved option I mentioned creates a 6 channel interleaved file and the size of the file ends up 3 times larger than what a stereo version would be (6 is 3 times larger than 2).
In the finder (if you're using a mac), the file may look like a stereo interleaved file (because both are displayed as 1 icon) but in reality, there are 6 channels in the file and, as mentioned before, the size is 3 times larger.
Am I missing something here?
Saki
Old 10-24-2007, 02:18 AM
Thanks for the information JKD, that makes sense. Much appreciated.
Saki
Old 10-24-2007, 04:18 AM
tj_davies tj_davies is offline
Command+Shift+K
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 10-24-2007, 08:34 AM
hahahah... I thought he was talking about a PT VERSION 5.1.. I should have read the whole post...thats what I get for thinkin,, SB
Question about mp3 bounce down bonzerboy General Discussion 2 11-12-2011 04:28 AM
Bounce Question bassbuddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-23-2008 12:20 PM
Another Bounce Question E-Buzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-22-2005 08:22 AM
Bounce question??? HR123 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-07-2003 12:12 AM
Bounce question elliprelli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-06-2001 10:34 AM
