hardware options for inserts
Right now I'm running PT7.2 with HD2 Acell set up on a G5 dual 2.3 using a 192 with a 24 bit Adat bridge off it's legacy port.
In the configuration I use for mixing I'm left with 6 analog insert points off the 192 (AES eats up two) and would like to have a few more for accessing outboard EQs, Comps and Verbs. Any suggestions on viable options at a cost less than another 192? Thanks |
Re: hardware options for inserts
A 96?
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur |
Well yes, but do any third party interfaces work? Apogee etc.?
apogees with a Digi card aren't less than 192's
something like this off the optical ports
http://www.rme-audio.com/english/adi/adi8.htm
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
The Lynx Aurora 16 with the LT-HD card provides 16x16 analog and 16x16 aes/ebu digital simultaneously with the exact same latency as the 192 units. Could work for you along with your Digi hardware (that's what it was designed to do, as well as be a standalone interface of course).
Joshua Aaron President/Chief Eng. AudioLot/AudioLot Studios Pro Audio Sales/Consulting http://www.audiolot.com Follow AudioLot on Facebook |
16 total. HTH |
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
a.i.r compresor also a.i.r gate greyout from inserts options plug-ins on PT 10 v 10.2 | jorgeorozco | Pro Tools 10 | 1 | 06-28-2012 09:59 AM |
hardware inserts | Andres Gonzalez | Pro Tools TDM Systems (Win) | 1 | 10-25-2008 05:25 PM |
Hardware Inserts in the Mix | Daniel_Dettwiler | Pro Tools TDM Systems (Mac) | 5 | 03-05-2003 05:13 AM |
L1 and hardware inserts | vtone | Tips & Tricks | 2 | 10-18-2000 09:43 AM |
