Old 01-12-2011, 02:25 PM
Julia B Julia B is offline
Default Garritan Aria Player Question
Okay, say I've created a jazz combo consisting of for example a flugelhorn, tenor sax, upright bass, and piano. In the Aria player I can assign them to different "channels" and load the combo and have the instruments panned to where I want them.
So what is the best way to use this as a plugin? I create an Instrument track. and I'm guessing I need to create four instrument tracks, four instances of ARIA, one for each instrument in the combo, and just have the particular instrument selected for each track?
PRO TOOLS 8 QUESTION: Also, is there an easier way of transferring the midi to an audio track other than bussing it over to an audio track and recording it?
Just trying to save some time.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz
IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte
L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh
Mainboard: DFI Inc. INF P35-R
BIOS : Phx Tech, LTD 6.00 PG 03/11/2008
Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus
MP APIC : Y
Tot Mem : 3.25GB DIMM DDR2 (WinXP)
Chipset: Intel P35/G33/G31 Proc
Front Side Bus Spd : 4x 266MHz
Mem Bus Spd : 2x 399MHz
(C:) : (250GB, SATA, 8MB Cache)
(D:) : (250GB, SATA, 8MB Cache)
Pro Tools 8.0.4 with Aria Player Plugins Finale 2012 FrankCan Pro Tools 10 2 08-06-2013 05:44 PM
VEPro - Aria - Multi not working the way I think it should in PT9 AlainZagar Virtual Instruments 1 11-13-2011 08:00 AM
Question regarding garritan jazz plug in cyndiek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-04-2009 09:10 AM
Once again: Sample Player question... maxserg Pro Tools TDM Systems (Mac) 4 02-25-2005 01:29 PM
Garritan Personal Orch/Kontact Player Problem offcentermusic Pro Tools TDM Systems (Mac) 4 05-25-2004 08:54 AM
