Using outboard Preamp/Bypassing Mbox2 Preamp
I have an Mbox 2 Pro that I use on my Mac. I have a Univ.Audio LA610 channel strip that I use as a Preamp for vocals and as a DI for bass. I am curious if there is a way to get around the Mbox2 preamp, because I can't seem to figure it out. I know the conversion sucks, and I accept that, but I still think it's kind of BS that I am forced to double my gain stages. Can anyone help me out here? Either a solution to this problem or $2000 to buy a Rosetta 200 would be great! Thanks!
2.16Ghz Mac, MBox2 Pro, Univ.Audio LA610, Line6 PodXT Pro, Line6 Bass PodXT Pro, Neumann TLM103, Dynaudio BM5A x2 |
Re: Using outboard Preamp/Bypassing Mbox2 Preamp
On the Mbox 2 it has 4 ins, 2 with preamps, mic/Line 1 & 2 and 2 inputs via SPDIF which require additional preamps. I assume it's the same for the Pro so SPDIF is the answer.
Cheers
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
That's what I was hoping not to hear... I think it's insane that you cannot bypass the preamps. I suppose I'll have to deal with it until I can come up with the money for the Apogee...
Not hard to believe when you look at the cost of the unit.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
if you go for the Apogee mini me / Mbox 2 combination, believe me, you won`t regret it!
Pro Tools 10 / Duet 2 - Eleven Rack - Mbox 2 pro MacBook Pro 2.2ghz Quad Core/ 8gb RAM/ 750HD Pro Tools 9 HD / 192io / C24 Mac Pro Quad 2.66 / 8Gb Ram |
wouldn't this pose the exact same problem though? from what i can tell, you can't bypass the preamps on the mini-me either. Sure the conversion will be better (a lot better), but the gain staging is still doubled. to me, it seems that going with something like the rosetta is the only answer. it would also give sweet d/a conversion for monitoring, and all the other nice-ities that the unit comes with. i think i am just going to deal with my problem for now and save for the rosetta 200.
002R Preamp and Outboard preamp | jimbojimbo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-21-2007 06:49 AM |
Bypassing Mbox 2 PreAmp | SoundtrackArcade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-14-2006 05:41 AM |
outboard mixer or preamp with MBOX | robert-l | Tips & Tricks | 17 | 07-12-2004 01:58 PM |
Bypassing Line Amp with a mic preamp | techdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-09-2004 12:08 PM |
Bypassing Line amp with a Mic Preamp? | techdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-09-2004 11:22 AM |
