Old 02-28-2005, 10:00 AM
arcarsenal arcarsenal is offline
Default URGENT URGENT Hard Drive problem please help
I was recording 2 bussed tracks to one and PT froze and what sounded like my hard drive was making this fairly loud churning/clicking/crunching noise so i did a force shutdown. i have 1 30gig with 3 partitions and 1 150gig for the audio.... Somebody please help me out I am panicing right now and I don't think I have to explain the significance of my life's work. What should I do????
Old 02-28-2005, 10:16 AM
mixerboy mixerboy is offline
Default Re: URGENT URGENT Hard Drive problem please help
You need to know which drive is playing up. Can you reboot? If yes, can you access the audio drive? Is the clicking sound still going on?
Assuming you can access, backup the audio immediately as it sounds like one of your drives is about to go if it hasn't already gone.
Old 02-28-2005, 10:26 AM
neomodo neomodo is offline
it doesn't sound good - when you start getting that sound you describe - you may be able to recover your data but it may not be cheap depending on how far gone the drive is. Did you back up your life's work?
Old 02-28-2005, 10:27 AM
After hearing this noise for about 15 seconds and shutting down, I booted up a minute later to see if it stopped and as soon as it started to turn on it started the noise again.
Do both hard drives spin up when you power on or just your OS hard drive? Because if its just your OS drive my recording drive may be fine. Im still scared to do anything right now.
Anyone?
Old 02-28-2005, 10:41 AM
Yes both drives spin on boot up.
Open your computer and disconnect the power cable to the audio drive and turn on the PC. If you hear the noise you know it is your system drive.
Old 02-28-2005, 10:47 AM
This is where I have a problem, which drive is my audio drive? I have two stacked on top of eachother, so i figured the bottom one is my audio drive, but i want to be sure.. is the secondary drive the one with the grey end of the cable and the main drive has the black end?
Old 02-28-2005, 11:01 AM
Your bios will tell you which drive is master/slave/primary/secondary.
Old 02-28-2005, 11:23 AM
lemix's Avatar
lemix lemix is offline
arcarsenal ,
Let's assume a typical configuration...( BTW..tell us what kind of drives you're using, and how are they connected )
Regular, IDE drives connected to the motherboard by an 80 conductor ribbon cable. The end of cable is the "master" and the middle tap is the slave. Your OS drive must be the master !
That scenario works, if they are both on the same cable/IDE controller. The other would connect to the optical drive/s, and/or additional hard drives...
good luck, hope this helps...
cheers,
Andrew
W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx
Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more
2.0 and 5.1 monitoring
Old 02-28-2005, 11:39 AM
[bleep], well i think i have some bad news...
I disconnected my recording drive and the computer booted up fine..
I dont even know what to do know... [bleep]......
What should i do? i am getting really depressed all of the sudden
Old 02-28-2005, 12:00 PM
neatguys neatguys is offline
send me an email arcarsonal.
Dont reformat that drive!!!!
[email protected]
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit
Urgent Problem...HELP~~~!!!!!! greekgeese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-08-2007 12:25 AM
hard drive formatting question...urgent...help presence known Pro Tools TDM Systems (Mac) 4 06-21-2005 12:03 AM
hard drive formatting question...urgent...help presence known Pro Tools TDM Systems (Win) 4 06-18-2005 03:58 PM
Problem going from PC LE to Mac TDM: URGENT who 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-16-2002 02:21 PM
Urgent Help! Lost audio drive AndiB Pro Tools TDM Systems (Mac) 10 09-23-2000 07:22 PM
