Old 01-10-2006, 10:12 AM
JAZZMO JAZZMO is offline
Default Sound Replacer
I've been having trouble with Sound Replacer. On some snare hits that I used SR on, which were processed to an open track, I get a flange sound. Anyone here had that happen? Any solutions?
Old 01-10-2006, 12:54 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Sound Replacer
This was the fix for me...
www.drumagog.com
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-10-2006, 05:32 PM
I demo'ed drumagog but decieded on SR. Per usual in my case there has never been another report on this particular problem. it seemed to work if I bypassed peak align, cross fade, dyn and mix.
Old 01-10-2006, 09:07 PM
ukoomrann ukoomrann is offline
Just tried the Drumago demo.
As someone who used soundreplacer from time to time Drumagog seems like a breath of fresh air
Trigggers better the latency is constant and not random and the ability to audition the sounds in real time is a huge diffrence
I am going for Drumagog
Old 01-11-2006, 07:37 AM
Alwyn Walker Alwyn Walker is offline
sounds like your snare sample is just phasing with your original snare sound. (each hit sounds different right?)
try a different sample or removing the original altogether from the mix (possibly duck the overheads if it still happens.
also, make sure the MIX setting in SR was entirely up.
the only other thing is try it with "peak align" on AND off.
Alwyn
http://www.komodorecordings.com
Sound Replacer mastermorris Tips & Tricks 2 01-28-2007 06:33 PM
Is there a drum replacer/sound replacer??? sethbrand General Discussion 2 03-08-2006 08:40 AM
my sound replacer makes the samples sound higher joeldavidlauver Pro Tools TDM Systems (Mac) 2 05-24-2005 07:59 AM
Sound Replacer Alters Sound of Sample. vze24x2x Pro Tools TDM Systems (Mac) 0 10-25-2003 07:10 PM
Need help with Sound Replacer Matty Spindel General Discussion 2 03-13-2002 11:55 PM
