Problems working from ISIS
Hello,
Had a search and couldn't find anything about this...so hopefully somebody here can help with this issue I'm having. We are a broadcast post-faciltiy running two Pro Tools HD 11 Systems with an HDX card, HD Sync, XMON ...both on Windows 7 64bit machibes (HP Z420) We are set up to run our sessions from a partition on our house ISIS - we are loving the workflow it allows when bringing media in from Media Composer..as well as being able to quickly open up sessions in either of our dub suites. We are however getting some problems that we cannot figure out. The first issue is that when running from ISIS a simple VO record session, we are experiencing a 5-9 second "hang" roughly every 30 seconds, when going into record....the systems locks up (still able to move the cursor) and then eventually drops into record. Not ideal when doing ADR and keeping clients happy! We tested this by tapping record/stop on and off and timing these hangs...this was happening consistently every 30-ish seconds. The same session suffered similar hangs for other functions (edits, clip moves etc), not just recording...but this one was easiest to replicate. When taking this session onto a local drive in the machine, there were absolutely no hangs and the system was also far more responsive when going into record. It was instant. So to us this proved that the problem is occurring when running from ISIS. The confusing part is, that we experienced this in several other ISIS sessions, but others would run with no problems. A 30 minute documentary works fine with no issues, even when adding a VO record track and trying the same test as mentioned previously. So it seems to be that for some reason, some sessions suffer from this more than others. The second issue is that our other suite is suffering from random -9171 and -9172 errors which interrupt playback and recording...again a horrible problem to have when reviewing projects with clients and recording voiceovers. We've looked into this as well but can't seem to find answers. This suite is running from the ISIS also. Any help at all would be very much appreciated as we are pretty confused by this. Cheers Will |
Re: Problems working from ISIS
Do the errors happen with a session running locally? Are you caching all the audio into RAM?
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Hi Brandon,
Running a session locally there are none of these problems. My cache size is set to "normal" and H/w Buffer is on 256 samples with dynamic plug in processing on and 256 voices. Another issue is that auto-back up session causes a delay when working from ISIS on a larger session e.g dialogue editing several channels of location audio. |
Hi
Did you ever manage to resolve these issues? I am running a very similar setup with 3 HD systems running PT11. We have to revert to working locally for VO recording and get the same freeze on each Auto Session Backup save. The advantages of working on the Isis means that we put up with these issues, but I would love to get them resolved. I would be very grateful for any tips. Many thanks Jeremy |
You have this problem even with disk enabled? How large is the cache?
And I'm just noticing the obvious mistake being made in this thread disk cache = "Normal" means that timeline/disk caching is *not* being used. it's a stupidly confusing menu. You have to set an explicit size. |
Ah. Didn't read 'Normal' in the previous post. We have cache set to, 4 GB. There is no problem pulling audio from the Isis, it's recording on the fly and session auto backups that are the problem.
Isis | Buccanears | Post - Surround - Video | 2 | 06-12-2012 03:53 AM |
PT? on Unity/Isis | Porky | Post - Surround - Video | 8 | 03-29-2012 10:11 AM |
? on ISIS | Craig F | Post - Surround - Video | 0 | 11-01-2005 03:52 PM |
pro isis marche pas | samys | Digidesign Hardware & Software | 2 | 11-15-2001 06:57 AM |
Uninstall PTF (ISIS) | maarten | Digidesign Hardware & Software | 1 | 11-08-2000 11:14 AM |
