Old 06-16-2005, 05:50 PM
toddw toddw is offline
Default No sound comming out of MBOX
Hi. I installed MacOS 10.3.9 on an external firewire drive along with protools (my main hard drive has Tiger installed, thus protools will not work). When I play a session using the firewire drive and it's version of protools, no audio comes out of the mbox. The meters light up, indicating that audio is being played, I just can't hear it. I CAN hear audio comming through the Mbox's inputs, though. Also, if I go into Reason and set audio out to Mbox, I will hear no audio, even though the application shows that audio is being played.
I'm afraid that the answer to this question will be very obvious, but I can't figure it out..
thanks
Old 06-16-2005, 05:58 PM
Default Re: No sound comming out of MBOX
Have you tried turning the Mix control on the Mbox?
Quad 2.5 G5, 4.5G RAM
Old 06-16-2005, 06:03 PM
I fixed the problem. I unplugged the mbox from the computer, then plugged it back in. I knew it would be something like that.
thanks
Waves V8 Comming! K.I. Pro Tools 9 6 01-25-2011 05:56 PM
Is Digidesign comming out with a New Command 8?? JGBalzac ProControl, Control|24, Command|8 17 10-20-2010 02:25 AM
Comming ProTools for SnowL in 64 Bit? clemens Pro Tools TDM Systems (Mac) 10 09-25-2009 05:21 AM
Amp Farm 3.0 Comming!! K.I. Pro Tools TDM Systems (Mac) 3 02-17-2005 02:34 PM
Dashboard is comming (again) pindebraende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-02-2001 03:41 AM
