Old 08-26-2019, 11:01 PM
senghor senghor is offline
Default a plugin to check your mix in mono
Hi!
I am searching a plugin that you can insert to your main bus to check your mix in mono. I have trying to find one?
Where can I have one?
My new Focusrite interface do not have this option.
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
Old 08-27-2019, 02:58 AM
unkJE's Avatar
unkJE unkJE is offline
Default Re: a plugin to check your mix in mono
Free!
https://www.plugin-alliance.com/en/p...s/bx_solo.html
Old 08-27-2019, 07:35 AM
This, and your monitor controller should really have such a button
Old 08-27-2019, 10:31 AM
amagras amagras is offline
https://www.bozdigitallabs.com/product/panipulator/
https://www.maat.digital/2buscontrol/
amagrasmusic.com
Old 08-27-2019, 11:02 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Originally Posted by senghor View Post
Hi!
You already have one. The AIR Stereo Width plugin that comes with Pro Tools. You can Maximize or Minimize it. IN minimal position its Mono.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 09-02-2019, 02:36 AM
I generally keep the bx_meter on my master, it has an option to solo the Mid signal which is effectively the same as Mono. They also have a free plugin, bx_solo, I think. I used to use that before I got bx_meter.
Old 09-02-2019, 05:53 AM
Stephen Bond's Avatar
Pretty sure monitoring the mono component of a M/S signal is different to summing a stereo to mono?
Anyhow, in the old Digi 001 days using the Waves S1 Stereo imager on the master was the standard with the width fader at 0.
https://www.waves.com/plugins/s1-stereo-imager
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 09-02-2019, 06:10 AM
No, not different at all.
Mono (mid) is sum of left and right channel. Stereo (sides) is difference of left and right channel. M/S techniques rely on this theory and it does not matter how you sum the channels. It is just convenient to click "mid" or "side" button on a M/S plugin.
Old 09-02-2019, 07:00 AM
I just double checked in Pro Tools for my own peace of mind and blow a few cobwebs away!
Indeed. I stand corrected. Summing to mono using the width on the S1 Imager (or Width at 0% on the AIR Stereo Width plugin) is the same as pressing the M button on any M/S plugin.
Each saw a -6dB drop in level of my test tone from hard left to mono.
Panning the channel to centre (using the pan pot) gives whatever the Pan Depth is set to in Session setup (-3.0 dB in my case).
Stephen
Old 09-02-2019, 07:41 AM
Great, don't just believe what I say excellent...
HTML code is On
Why check your mix in mono? KevinAllen General Discussion 29 01-28-2010 01:15 AM
does anyone know to check a mix in mono? Help??? cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-23-2008 08:07 AM
How can I Check my mix in Mono? Derekten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-01-2008 01:57 AM
Check Mono....? danwillrock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-19-2007 04:10 AM
mono check uwehaas Tips & Tricks 4 12-07-2005 08:28 AM
