Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-30-2020, 09:14 PM
RuffinMedia RuffinMedia is offline
Default Does Pro Tools still work with Reason via rewire?
Does the current version of pro tools work with Reason's rewire plugin? For some reason, I dont see the rewire plugin when attempted to add it to an instrument track. When I used pro tools and reason years ago, you could use both Pro Tools and Reason in sync using a rewire plugin.
Mac Mini 2.5 GHz Dual-Core Intel Core i5 - 16gb Mem - MacOS Catalina 10.15.5 - Pro Tools 2020.3.0
Old 07-01-2020, 01:33 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Does Pro Tools still work with Reason via rewire?
Yes it still works. On my system there's actually a Reason plugin under Instruments that when selected will open Rewire.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 07-01-2020, 01:36 AM
Thanks for clarifying.
Now this means something is wrong with my system. I tried reinstalling reason 10 lite and reason 8 but it still doesn't show up in pro tools as an instrument option. Is there a way to install rewire?
Also, Ableton live does show up as an instrument option in pro tools.
Old 07-01-2020, 02:04 AM
Rewire is not included in Lite.
What are all the plugins that show up under Propellerhead?
Old 07-01-2020, 08:51 AM
The Weed's Avatar
The Weed The Weed is offline
His sig say PT 10 with the CPTK. I'll have to assume that's correct and that Reason 8 is AAX?
If the sig is correct, maybe the Mods can move this to the PT 10 forum.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-01-2020, 09:58 AM
Sorry for the confusion. My signature was outdated. I changed it to what I currently have.
Also, Ive included what options i have in the pro tools plugins list.
File Type: png Screen Shot 2020-07-01 at 9.57.05 AM.png (87.0 KB, 0 views)
Old 07-01-2020, 12:35 PM
cwsand's Avatar
I'm not sure where the Reason plugin is stored - it doesn't show up in the folder where most all the other plugins are stored.
Have you trashed Preferences? That should force a rescan of all the plugins when you start Pro Tools so maybe it will show up.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 07-01-2020, 01:14 PM
Again -- What are all the plugins that show up listed ***under Propellerhead***? ie. organize plugins by Manufacturer.
Reason 8. Does that even support AAX-64? I'd be surprised, if you want to curate a plugin museum you should know this/have checked it already...
But go check... is the rewire plugin installed in the plugin folder at all? Seems an obvious thing to check.
If it is what is the actual executable type for the plugin?
e.g. in Terminal, with Trim as an example...
$ cd /Library/Application Support/Avid/Audio/Plug-Ins
$ file Trim.aaxplugin/Contents/MacOS/*
Trim.aaxplugin/Contents/MacOS/Trim: Mach-O 64-bit bundle x86_64
(showing Trim.aaxplugin in this install is an AAX-64 plugin only)
Old 07-01-2020, 03:48 PM
cwsand's Avatar
I'm using Reason 8.3 successfully with Pro Tools 2020.5.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
Slate Digital VRS8
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
Old 07-01-2020, 04:25 PM
OK then now we know that is supposed to works. It would be good to see the actual plugins physically installed in the folder.
Wasn't there also something about getting Reason in 64-bit mode as well if working with AAX-64 ... can't find a link to that.
Can't get pro tools 11 to rewire reason 7 Bigalsmuzik527 Pro Tools 11 6 12-29-2014 12:16 PM
Pro Tools 8.0.4 Rewire with Reason 5 mexablcknesekid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-07-2010 03:50 PM
Pro Tools LE 7.1, Reason & Rewire seeclouds Pro Tools M-Powered (Mac) 2 07-21-2009 12:40 PM
reason/rewire does not work sweet Pro Tools M-Powered (Mac) 1 06-15-2008 10:16 AM
Cant Rewire Reason to Pro Tools choodelphia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-28-2005 12:00 PM
