Old 10-29-2013, 04:43 AM
boomstand boomstand is offline
Default Unique Plug-In Lateny Issue only in 11, not 10
Hello all, this is my first post so try to bear with me, haha.
I know there are a lot of posts about latency issues in 11, but I haven't seen anything on this particular issue.
When I track and play back, everything is where it should be. No latency. As soon as I add a plug in, the latency begins, but this is the weird part. If I turn on Delay Compensation, the track that contains the plug in is on time, but the rest of the tracks fall behind. If I turn off Delay Compensation, the reverse happens. BUT, this problem does not actually appear until I simply arm and disarm another track that does not contain a plug in, which led me to believe that it is a bug. This appears to be happening with any plug in I use, and the amount of latency seems to be appropriate with the amount of delay compensation the plug in requires. The issue is non existent in 10. I am very puzzled by this.
Any thoughts?
MacBook Pro Mid 2012
2.4 GHz Intel Core i7
16 GB 1333 MHz DDR3
Mountain Lion 10.8.5
Saffire PRO 40
Pro Tools LE 10.3.7
Pro Tools LE 11.0.2
Old 10-29-2013, 10:43 AM
surstromming surstromming is offline
Default Re: Unique Plug-In Lateny Issue only in 11, not 10
It sounds very similar to a problem I discovered a while ago in this thread:
http://duc.avid.com/showthread.php?t=345771
If it is not exactly the same, could you please try what I´m doing in the video and post if you see the same problem.
Regards,
Markus
Windows 10
Intel core i7 4790k, 16Gb ram
MacBook Pro Retina 13" late 2013 OSX 10.12
Intel Core i5 2,4 GHz 8GB
Pro Tools 2018.4
Eleven Rack + Expansion pack
RME Fireface UCX
Old 10-29-2013, 11:05 AM
Top Jimmy's Avatar
If no one gets to this sooner, I'll have a go at this tonight to see if I can replicate this behavior.
Parroted on my iPad with Tapasquawk.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 10-29-2013, 09:59 PM
Top Jimmy's Avatar
I've duplicated this behavior and have kicked it up the chain.
James Cadwallader
Old 10-30-2013, 04:30 AM
Yes Markus, that is the same behavior I was experiencing.
Sent from my XT1080 using Tapatalk
Old 10-30-2013, 01:36 PM
Ok, hopefully this will be fixed since Top Jimmy has duplicated this.
Till then you can use the trick I did in the video as a work around.
Just make your outputs inactive and active again
Regards,
Markus
Windows 10
Pro Tools 2018.4
RME Fireface UCX
Old 10-30-2013, 02:04 PM
DonaldM's Avatar
DonaldM DonaldM is offline
This is an odd problem. If its a bug, why aren't we all experiencing it? I havent had any latency issues with 11 no matter what I do. But I'm on Win-7. Maybe its a Mac thing?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2019.10
Focusrite Scarlett 8i6
Old 10-30-2013, 02:07 PM
I'm on windows 7 and I have this problem.
Have you tried what I did in the video in the other thread?
Regards,
Markus
Windows 10
Pro Tools 2018.4
RME Fireface UCX
Old 11-04-2013, 04:03 PM
Top Jimmy's Avatar
Avid has recognized this bug and it is now in the official tracking system. There is no information as to when a fix will be provided.
James Cadwallader
Old 11-04-2013, 05:14 PM
Which plugin? Have you trashed preferences? I had 1 time when delay comp was wrong, but turning it off and back on put things back in order here.
Unique ID bcwiz Pro Tools 10 4 03-17-2014 05:42 PM
PT 9.0.6 Start/Stop Issue and Plug-in Instrument Issue ZDF macOS 0 01-14-2013 02:47 PM
Lateny Issue with PT8, 2009 mac Pro (OSX) and NI Plugins/Spectrasonic Plugins djtorch Pro Tools M-Powered (Mac) 1 01-14-2010 12:11 PM
Unique ID keny Pro Tools TDM Systems (Mac) 9 09-16-2006 09:24 AM
unique id bongo_x Pro Tools TDM Systems (Mac) 0 01-24-2006 01:23 PM
