Old 07-23-2012, 10:46 AM
texasdave texasdave is offline
Default Eureka Sound Prom question
Can't get to the contact page on the eurekasound page for some reason... Does anyone know if the EurekaProm will let you set the min/max values in "Stompbox" mode on the Behringer 1010? I haven't found anything to tell me "yes."
Texasdave
Old 07-23-2012, 11:09 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eureka Sound Prom question
min/max values for what exactly? The expression pedals?
You can contact them directly at:
dave AT eurekasound DOT com
Old 07-23-2012, 01:30 PM
no, the "StompBox" style switches ...it's back to my controlling values within effects via MIDI... More (than I realized) will only send 127 and 0 in the stompbox mode. Behringer 1010 with UnO prom will let you set min max values other than 0/127 as I do on the Roland FC-300...
Thanks for that email...
Texasdave
Free FCB1010 Eureka! PROM cage77 Eleven Rack 1 11-10-2013 03:41 AM
11R with FCB1010 & Eureka Prom rexrandom Eleven Rack 1 10-12-2013 02:41 PM
I have no idea how to use fcb1010 and eureka prom mesaman4 Eleven Rack 2 03-07-2013 08:24 PM
Trouble with eureka prom when using volume pedal Peter Kroner Eleven Rack 4 03-06-2013 04:20 AM
Eureka prom installed but the exp pedal wont calibrate right Jd0g33 Eleven Rack 4 12-02-2011 01:23 PM
