Old 01-10-2012, 12:22 PM
Webb Webb is offline
Default Eleven Rack EXP Pack after PT 10 upgrade
I have an Eleven Rack with EXP pack currently running on PT9 OS X 10.6.8. I just upgraded to PT10 and figured it's a good time to do a clean install of 10.7.
Once I do a clean install and load PT10, do I need to do anything additional with the Eleven Rack in order for the GUI in PT10 to recognize the EXP pack? I don't need to reinstall the EXP pack, right? I should be good to go??
Old 01-10-2012, 01:16 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack EXP Pack after PT 10 upgrade
You do NOT need to update the firmware again. But you will probably have to run the first part of the ERXP to get the UI files back into Pro Tools, just run the first section, then delete the firmware updater that gets placed on your Desktop.
Old 01-10-2012, 01:40 PM
Thanks dude... I was just actually watching your YouTube tutorial on reamping with S/PDIF. Very helpful!
Old 01-10-2012, 08:21 PM
texasdave texasdave is offline
it was pre-Christmas when I got PT10, but I *think* it had the drivers for the exrp...either that or I downloaded latest drivers for 11R... anyway, I uninstalled 9, installed 10, and I don't recall having to run the exrp to get the gui to work correctly. I had a new unit that shipped with EXRP. There, that was no help other than to say if you download latest 11R drivers it may not be necessary to do anything else in PT10.
Old 01-11-2012, 11:16 AM
Benoni's Avatar
Just to clear things up here, the ERXP does not need "drivers" its the Eleven Rack that uses drivers. True, you have to have the drivers installed in order to install the ERXP, but that has to do with the Eleven Rack, not the ERXP.
if you had PT9 installed and used the ERXP installer to insert the UI files, then simply uninstalling PT9 won't get rid of the Plugin folder in which the UI files and other plugin files reside, unless you do a complete uninstall. So that is more than likely why you did not have to re-install the ERXP (first section only)
Unless of course Avid has started including the updated UI files in the PT10 install. They were not in the PT10 for the trial I used, but its possible they are now included, i have no way to confirm if they are or not. Im sticking with PT9.
Avid is supposed to eventually include the new UI files in Pro Tools, so maybe they have done so.
But either way, its not a big deal. I they are present, then everything will work just fine, if they are not present, then simply run the first section of the ERXP, and you are good to go.
Old 01-11-2012, 11:34 AM
sorcerer27 sorcerer27 is offline
I see no evidence that it's incorporated in PT10 yet. Perhaps in the next update.
Eleven Rack with Expansion Pack Hendrix95 Buy & Sell 2 07-21-2012 06:44 PM
will there be a new expansion pack for eleven rack? dbvoyager Eleven Rack 19 06-05-2012 07:32 PM
Eleven Rack Expansion Pack Legion6789 Eleven Rack 6 01-10-2012 10:23 AM
Eleven Rack Expansion Pack Hank Marvin Eleven Rack 16 08-31-2011 06:12 PM
Eleven rack expansion pack reycantong Eleven Rack 11 01-25-2011 01:31 PM
