PT 9 and the original Digidesign Midi Interface.
Hey All,
Being the 'Midi Virgin' that I am, does anyone know if the original Pro Tools Midi Interface (grey 1U unit) will work with PT9/10, and if so, if there a way of double checking that PT can actually 'see it' ? The reason for asking is that when I try and generate MTC, the only ports that appear to be available are a number of Euphonix ports. (I should mention that I'm using 2 x MC Mix's and an MC Control ). If anyone can enlighten me on the basics of MIDI, I'd be eternally grateful. My warmest regards to you all as always. Alex |
Re: PT 9 and the original Digidesign Midi Interface.
I've never even heard of this?
If it has a driver and works in your OS then it should work in Pro Tools. If you want to know if OSX see's a midi device open audio midi setup and it should show there, for the PC.....ergh??? If you want to test if a device is delivering midi to the OS then you can use Midi-ox for PC or Snoize Midi Monitor for mac. I wouldn't hold out much hope.........but good luck!
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Thx for your words of wisdom Sir; managed to get it going perfectly with PT9 without too much blood, sweat and tears.
Warmest regards. Al --- I am here: http://tapatalk.com/map.php?okztsu |
Digidesign MIDI interface | 685 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-09-2006 01:06 PM |
midi interface and HD non digidesign | fasttraxx | Tips & Tricks | 0 | 09-08-2004 03:41 PM |
Digidesign MIDI Interface | ikke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-06-2004 04:41 PM |
Digidesign MIDI interface` | hiltonius | Pro Tools TDM Systems (Mac) | 1 | 08-11-2002 05:54 PM |
Digidesign MIDI Interface | Baba Omar Jun | Pro Tools TDM Systems (Mac) | 1 | 05-26-2000 07:09 AM |
