Re: How should I install Structure after PT9 upgrade?
Aaron Mulqueen - 001 HD Native |
The only way I can load a factory patch, is to navigate the long way via MacHD/Applications/Digidesign/Structure/Structure Factory Libraries each time I want to pick a patch. It's not supposed to be like this, is it? A question: After installing the five DVD's with content for the full version of Structure, what are the names of the folders? Are these the 15 folders where the first is named "01 Acoustic Drums" and the last "15 Surround Atmospheres"? Are these the patches that were installed with the encrypted .big files? |
This is the folder directory: Hard drive:\Structure\Structure Factory Libraries and in Structure Factory Libraries folder should be these folders including the Structure Encrypted Samples. This is all by default.
In the folder MacHD/Applications/Digidesign/Structure/ you should have an application called 'Set_Structure_Content_Location'. Did you try running this?
If this doesn't work, try the alias method I suggested earlier in this thread. Failing that, full instructions for command line-based rebuilding of the database can be found here: http://duc.avid.com/showpost.php?p=1366084&postcount=4 |
I have sent a special support request, but there is no response from Avid. Well, I may end up removing both ProTools and Structure and get rid of this brand. I am so disappointed when thinking about how great Digidesign was in the beginning, and how poorly they have managed in the last five years. |
#16
I finally got response from Avid Support, and they said that I needed to buy the upgrade to Structure 1.1 in order for this to work with OS 10.6 and PT9. I thought I had the latest version, but that was not so. After purchasing the upgrade (which I think should have been a free update...) and downloading and installing all the five DVD's again, the content with presets became visible within Structure. What I suggest to Avid, is that when an upgrade or update to ProTools is installed, the installer should check if the current Avid-plugins that are installed, are compatible or not. This is what I'm used to with other music software.
Structure Free to Structure Upgrade | davidlemonds | Virtual Instruments | 3 | 09-07-2011 03:23 PM |
Structure 1.10 won't install, OSX 10.6.8 | filmsound_no | Virtual Instruments | 1 | 07-31-2011 01:04 AM |
Structure free upgrade to structure 1.05? | airlee22 | Virtual Instruments | 1 | 05-17-2011 01:17 PM |
Srtike and Structure Install Help | Blackthorn | Pro Tools TDM Systems (Win) | 2 | 07-22-2010 02:08 AM |
scared to install structure le | fish52986 | Virtual Instruments | 3 | 03-16-2009 12:36 AM |
