Pro Tools 2018.7 crashes when closing a session
Anyone else seeing this?
Sent from my iPhone using Tapatalk |
Re: Pro Tools 2018.7 crashes when closing a session
This generic issue has been discussed before on DUC. Most likely suspects are corrupt sessions or bad plugin. What have you changed recently? If there was a serious problem with 2018 I think we'd be hearing lots about it. Always possible that a specific plugin or two have been tripped up by something in a Pro Tools release and not many see it.. so important you troubleshoot for plugins if it's not a corrupt session.
Did you try trashing prefs? This happen on only one session? If so import that into a new session or use your last working backup. Otherwise plugins... see standard troubleshooting steps are under "help us help you" up top of each DUC web page. |
Hi there.
I have protools crashing when closing. Also with no plug-ins at all. I'll try to re-install and let you know.
eMachines M6811 1.25 GB RAM Internal 5400 RPM 80 Gb External 7200 RPM 160 Gb Maxtor Firewire MBOX + 002R ProTools LE 6.4 Ableton Live 5.2 |
If you are going to r-install, remove all of your plugins as well. With no plug-ins installed, run PT and see if it exits cleanly. If it does, then add back your plug-ins one by one until you find the one that is causing the hang on exit.
I’ve been using 2018.12, issue seems to have gone away so far....
PTHD 9.0.6 crashes when closing session | jrmintz | macOS | 0 | 04-06-2014 09:58 AM |
PT 10.3.8 Crashes after closing session | drvibb | Pro Tools 10 | 2 | 03-20-2014 03:17 PM |
PT HD 7.4 crashes when closing a session | deardaddy | Post - Surround - Video | 10 | 05-21-2009 03:01 PM |
Crashes when closing session Pro tools 7.0 | Drive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-07-2006 01:34 AM |
pro tools app. crashes when closing session | Blake Henderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-27-2001 04:22 PM |
