Old 05-23-2019, 01:43 AM
marmouche marmouche is offline
Default Revibe 5.1 protools ultimate
Hi
Since we've installed the last protools version, i can no longer hear the reverb on the center when i use a revibe 5.1, only some weird E/R without any tail.
Still can tweak the front and rear side but i have to load the same verb in mono on an other aux to have center... It's like the a quad verb now :/
Wasn't the case on previous version so wonder why 5.1 verb is no longer a 5.1 verb (maybe there is on option to check or something ?)
Thx for your answer
Old 05-23-2019, 05:45 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: Revibe 5.1 protools ultimate
In the "Levels" section, make sure "Center" is turned up (it's -inf as default).
Old 05-23-2019, 06:08 AM
marmouch273 marmouch273 is offline
YEah it is for sure
When I turn it up ain't got any reverb just e/r like I said, it's really weird :/
Old 05-23-2019, 11:41 PM
Any other idea ?! Using a lot this verb and it make me lose a lot of time
Old 05-24-2019, 02:24 AM
Farhoof's Avatar
I'm not seeing the same issues here, al is working fine.
What version of Revibe are you running? Mine is 18.1 (and PT 2019.5)
Old 05-24-2019, 03:07 AM
Thx farhoof for your concerne
Using protools ultimate 2018.7.0 and revibe 18.1.0.1441 (😬?!)
Old 05-25-2019, 01:32 AM
FritsFlits FritsFlits is offline
A while ago we encountered this issue as well and found it the newer version/versions of RevibeII had this problem, while the older version worked fine. So I assume the issue hasn't been resolved yet.
I'm not at work, otherwise I could have looked up the correct working version, but maybe you can find a previous installer of the plug-ins. I think the correct one was before or in the early PT2018 versions. If you aren't able to find a working one I can search the right one for you next week.
Old 06-06-2019, 03:06 AM
Hi frits
Would be great if you could find the good version that works well
Would allow me to save a lot of time !
Thx by advance !
HTML code is On
Protools Ultimate 2018.7 + Maschine day_tripper Pro Tools 2018 5 01-10-2019 07:47 PM
windows 10 protools ultimate bug stanonbass Pro Tools 2018 1 05-07-2018 06:28 PM
ProTools 12 Ultimate - CPU Overload without playing Aquic Pro Tools 2018 38 04-25-2018 07:05 AM
protools hd native 10.3.9 and Revibe Cryos Pro Tools HDX & HD Native Systems (Mac) 0 01-23-2015 07:06 PM
Revibe on Protools HD 7.0 Magno Pro Tools TDM Systems (Mac) 2 11-07-2005 06:15 AM
