Old 06-09-2011, 02:43 PM
tanjerinepost2 tanjerinepost2 is offline
Default Dragging files into PT's 9
Hi All,this is a weird one, whenever I drag files in from Workspace,Finder,Catalogs or Audio finder I get the spinning beach ball for about 10 to 15 secs.This only occurs on the first drag from the source..if I don't change views in any of the sources and drag another file in it works perfectly.If for instance I then change my view to a different folder in finder or a different catalog search the problem repeats itself.This happens with both network drives and local drives.However, if I disconnect my network connection and repeat the same processes it works perfectly!!Has any one seen this before and could offer any advice.BTW this has only manifested itself in PT9 all worked fine in PT8 and has identical symptoms on all of our HD systems.We've upgraded to 9.03 but has not made any difference.Thanks
Mac Pro TrashCan 3.7 Ghz Quad Core
AJA Video Op
PT 11.3.1 2xHDX
S6 32 Fader
32 Gb Ram
Old 06-10-2011, 07:11 AM
daeron80 daeron80 is offline
Default Re: Dragging files into PT's 9
Actually, not so weird. Lots of people on Mac having the same problem.
David J. Finnamore
Nyquist was right.
PT 2019.6 Ultimate | Omni | macOS Sierra
PT 2019.6 | Saffire Pro 40 | Win10
Old 06-11-2011, 04:44 AM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
It's been a drag to drag from finder since PT 9.
Vedat
Check out WaveRider + Defaulter:
QuietArt.co.nz
Catchin' SYNC app
Old 06-13-2011, 07:59 AM
emreramazanoglu emreramazanoglu is offline
same here
Old 07-09-2011, 12:27 PM
goldfishsound goldfishsound is offline
I've found that removing my network cable "takes care" of this problem. Insert the network cable again and the problem returns. Seem Pro Tools is waiting for some system response when connected to a network, and that is halting pro Tools in doing it's business.
Old 07-09-2011, 02:46 PM
Hi All, We've fixed this by following the instructions in this thread...worked a treat for us !
AJA Video Op
PT 11.3.1 2xHDX
S6 32 Fader
32 Gb Ram
Old 07-09-2011, 02:47 PM
Sorry,this thread....http://duc.avid.com/showthread.php?t...ht=drag&page=3
AJA Video Op
PT 11.3.1 2xHDX
S6 32 Fader
32 Gb Ram
Dragging audio files downwards is slow?!?!?! abayman65 Post - Surround - Video 6 06-21-2011 02:08 PM
Dragging MIDI files into 8.0.3 lennieh Pro Tools TDM Systems (Win) 2 03-04-2010 04:35 PM
EZ Drummer? PT Error dragging midi files TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-28-2008 12:16 PM
Dragging 5.1 files from workspace OysteinHalvorsen Pro Tools TDM Systems (Mac) 2 12-22-2004 05:21 AM
Dragging new audio files hyrobase75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-17-2004 02:42 AM
