Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 09-28-2010, 07:06 PM
Kemo3ce Kemo3ce is offline
Exclamation Bouncing tracks quality loss.
Ok I am new to pro tools and I have a question when u r done mixing everything how do u export? Bouncing tracks or another format, I recorded in 24 bit. 96 kHz and now when I bounced to 1 track stereo 16 bit 44.1 I lost highs and gained some bass any reason y?
Old 09-29-2010, 08:47 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Bouncing tracks quality loss.
I prefer to record back into the session INSTEAD of bouncing out. This gives you the opportunity to tweak the mix even more as you go, if you want, and if you hear something you don't like you can stop, fix it, and punch back in, consolidating the file when you're done. When you're happy with it, then you EXPORT THE REGION as a new file at the sample rate and bit depth you prefer.
To do this requires some real thinking on your part, as you setup the mix-desk using BUSSES which are then routed to your record track, with the record track outputs feeding your monitors.
This gives you lots of options as well, such as putting the rhythm section on a stereo buss (with dynamics if you wish), putting the vocals on a stereo buss (dynamics, etc.), guitars on one and keys on one, etc., etc., etc. All of the buss outputs then feed a final stereo buss (with dynamics if you wish) which feeds your mixdown track.
We've been doing all of our 'bouncing' like this since early 2004 and it works MUCH better than the typical 'bounce' does.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 09-29-2010, 10:05 AM
clausiii's Avatar
clausiii clausiii is offline
Bounced should not sound bad, there is something wrong!
Is your Master clipping? Is your sound device in sync? Is/was it in sync when you listened to your bounced audio?
How did you listen to your bounced track? iTunes or similar? Does your audition application have any EQs or Compression on (iTunes has something like this!)
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 8GB RAM
ProTools 2018.12
Digidesign Command|8
macOS Mojave
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
tons of stomp boxes
tube amps
guitars
noise
Old 09-29-2010, 10:17 AM
Dism Dism is offline
Are you using dither? Otherwise, what you are experiencing is truncation.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 09-30-2010, 02:48 AM
Hmm... Dither? I'm not to sure a out what that means but I'm just bouncing it down and I listened to it on cool edit pro I moved the huge wav file to my pc to listen to it over there. And hey that mixing back in to the session sounds like a real good idea... It should enhance the mix alot more too since your focusing on groups mixes after the individual mixes that's a very good idea. Thanks guys well I'm gonna keep fiddling with it and see what comes out I don't know y it sounds like that, maybe it's cool edit.
Old 09-30-2010, 02:55 AM
Oh everything thing was in sync, if it wasn't would that cause something like this to happen?
Old 09-30-2010, 07:50 AM
http://en.wikipedia.org/wiki/Dither
There are plenty of resources out there defining dither.
I would suggest learning about it if you are going to mix in a higher resolution than what you bounce down to.
D
Old 09-30-2010, 09:33 AM
Ok I will thanks for the input. I really appreciate it.
Old 09-30-2010, 09:43 AM
I have another question, if u lose alot of fedelity going down to 16 bit then what's the point in recording in pro tools hd at 24 bit 192 kHz? If in the end ur loosing alot of the sound quality that u want? Sorry guys I'm new.
Old 09-30-2010, 09:58 AM
You don't really lose all that much fidelity in going from a higher samplerate to a lower one. In fact, most people wouldn't really be able to tell the difference between 192k and 96k, or even 44.1k for that matter. Not only that, but the disk space required for 192k wave files is borderline ridiculous.
Where you lose quality is in the bounce. Hence why dither is important. When you bounce from a higher bit depth/sample rate, there is data and detail being lost. Without dither, this lost detail becomes apparent, because you end up with aliasing and quantization error. Think of when you reduce a high quality image to a lower one. Without compensation, you end up with a grainy, pixelated looking image. Most photo-manipulation software will automatically compensate for this by applying dither. Dither is essentially "noise" that fills in the lost information and smooths out the image. The same goes for audio.
The next time you bounce a file from 96/24 to 44.1/16, put an instance of POWrdither on the master fader and see if there's a difference.
D
Questionable quality loss JimHalpert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 10-17-2010 06:39 PM
Loss of audio quality in editing Mastered Tracks in Pro-Tools? allnightmusicman General Discussion 17 04-29-2010 11:10 PM
Upsampling 48k to 96k Quality Loss? perspectrum Pro Tools TDM Systems (Mac) 1 02-23-2004 10:25 PM
Why does consolidation &or bouncing tracks=loss of sound quality John Kurzweg Pro Tools TDM Systems (Mac) 38 07-24-2003 08:22 AM
How to improve audio quality when bouncing tracks krhaarmeyer Tips & Tricks 1 12-31-2000 01:37 AM
