Old 11-21-2018, 11:37 AM
DieselDungeonStudio DieselDungeonStudio is offline
Default Using 2 BCF2000 in BabyHui Mode in Pro Tools 12 on Windows 10
Hi there,
I have had and used successfully 2 BCF2000 units for the last 6-7 years on my mid-2011 Apple imac. They worked great in getting me 16 channels of control faders (each unit was plugged into it's own USB port) in pro tools 9, 10 and 11. Well my imac died and now I have a PC with Windows 10 Pro 64 bit, and I upgraded to Pro Tools 12.4 Native.
On my new PC I downloaded the latest drivers i could find online (couldn't find them on Behringer website under BCF2000, only some other USB Audio Midi driver, but it wasn't for the BCF2000). The drivers I downloaded and installed say the following under Device Manager:
Driver Provider: Behringer
Driver Date: 12/15/2009
Driver Version: 1.0.10.0
Digital Signer: Ploytec GmbH
I originally just setting these up in PT on my PC without downloading or installaing any drivers...Windows auto-detected them plug and play. But after the units weren't working in PT, that's when I tried installing the drivers I talk about above.
I have what i believe to be the latest firmware on the BCF2000's...haven't changed it since I was using on the imac...V1.10
When i view "Bluetooth and Other Devices" in Windows 10 Settings, i see 2 instances of "BCF2000", so my computer appears to be seeing them.
Under "Device manager" in the Control Panel in Windows 10, i can see 2 instances of "B-CONTROL", and if i click each of them, it says "This device is working properly", so again, this leads me to believe my computer is seeing them.
I have both BCF2000's setup in BabyHui mode by holding down Solo button 5 upon boot up of each BCF2000.
When i launch Pro Tools 12 and click Setup>Peripherals, click "Midi Controllers" then select "HUI" as the Type, then click "Receive from", the only option i get is "BCF2000 (Emulated)". Then I click "Send to" and again the only option i get is "BCF2000 (emulated)" so i select that.
Now, i can't see a 2nd instance of BCF2000 for midi peripherals in Pro Tools 12 on Windows. Before I could on imac in PT9, 10 and 11, but now i can't.
The one BCF2000 works flawlessly inside Pro Tools. The other one can't be seen under PT peripherals (but the PC itself sees it).
What to do?
Please help as this has really interrupted my workflow.
Thanks!
Old 11-21-2018, 01:47 PM
ChuckS ChuckS is offline
Default Re: Using 2 BCF2000 in BabyHui Mode in Pro Tools 12 on Windows 10
Did you set different Device IDs for the units? It's part of the global setup, like MIDI channel, etc. Don't know if that will work with PT because you don't enter an ID in setup, but maybe worth a try.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 11-21-2018, 09:58 PM
secondtyme secondtyme is offline
What he said. I was using different interfaces 10~12 years ago with a PC. Using a Tascam DM4800 today with 32 I/0s
Old 11-23-2018, 08:49 AM
Ths is not related to I/O audio interface though. Just BabyHUI control surfaces.
Old 11-23-2018, 08:51 AM
Yes I tried that per someone else on a different forum suggesting that (which worked for them). PT refuses to see this other BCF, but the PC sees it in more than 1 place I look. So frustrating. Maybe start from scratch? But I don't know how to get rid of the drivers I downloaded for those...may roll back t the generic Microsoft auto-read drivers and mess around with that again but no idea how.
Old 11-23-2018, 12:24 PM
Anyone else? I'm fairly certain at this point that it is a Pro Tools issue.
Pleeease I beg of your help! lol
Old 11-27-2018, 06:56 AM
Bump, anyone? Pretty please?
Old 11-27-2018, 08:56 AM
If you have a MIDI interface, you can try connecting them via MIDI cables instead of USB. That way you'd be certain to have them assigned to two separate MIDI ports and use those ports in the periphs config.
Old 11-29-2018, 10:21 AM
Have you got the DM working in any other configuration? For instance does the Windows "start up" chime when you load Windows? I seem to recall, (10 or 12 yrs ago, haha) that 1. having the monitors plugged into a different output that was not correlated to the monitor button that I was pushing on the top of the mixer. 2. the XLRs are not balance outs, they are digital outs. Can you hear anything in the headphone jack.
What I'm saying here is that maybe it is working, but that you just can not monitor it?
Can you see your device listed in Pref or Options? (sorry I can't remember which at the moment)
Click auto format in the I/O page and make sure it's seeing your device.
Good luck
Old 11-29-2018, 10:25 AM
Good luck
BCF2000 in BHUI mode under W7 64bit KARLITOSUK Pro Tools 10 1 06-13-2013 10:32 AM
Running Pro Tools Le/ M-Powered in compatibility mode using windows XP service pack 2 fuddbeer Pro Tools M-Powered (Win) 2 11-06-2010 11:37 AM
How do I put the BCF2000 in Hui Mode? JRodJr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-16-2006 01:13 PM
PT6 and BabyHUI Problems Macman126 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-25-2003 08:16 PM
Babyhui and the digi 001? Big Koo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-15-2002 11:59 PM
