Old 03-02-2004, 07:32 PM
mersisblue mersisblue is offline
Default 001 MIDI ports aren\'t working ???
Hi
my 001 in and out aren't taking any signal in from any of my midi units I have them set up in midi studio setup
correct ......midi thru.enabled. tracks set correctly ............... but no signal is in PT ? I tested this with all my midi
cables ( like 6 different cables ) one of the midi dev ces I tried always sends signal no different setting for
sending midis o I know its my 001 or PTLE ??? I would like like to know if it's le before I would have
to get it fixed ( that is if it's not { pt le}) Im on
OSX 10.2.8
LE 6.1.2
001
I need my midi back
midi back midi bak midi back
midi back midi bak midi back RIBS
no seriously help me
Old 03-02-2004, 11:34 PM
Default Re: 001 MIDI ports aren\'t working ???
ok where can i get it fixed ?
Old 03-03-2004, 12:11 AM
Im still under warranty 1 year right ?
Old 03-03-2004, 07:57 AM
dans dans is offline
before sending it in to be fixed, I'd look into configuration more. I don't use MIDI so I'm not much help, but when I bought iLife I checked out Garage Band and it worked flawlessly the first time I launced it. I expected some kind of MIDI issue with my 001 from what I had read about MIDI, the 001 and PTLE 6. But it worked "out of the box". Maybe you should try PTLE 6.2.x and OS 10.3.x?
Hmmmm, let me look at your store receipt. Oh, wait, I don't have your store receipt, only you have that! Well, what's it say? Did you buy it a year ago???
It's not what you know that is important...it's what you can figure out.
G4 1.25DP/FW800/1.25GB/OS X 10.3.5/Digi 001/LE 6.4
Old 03-03-2004, 01:21 PM
yes i have the reciept
and it is my understanding that core audio does not support midi
and unless someone can tell me what to check in the midi setup , I am pretty knowledgeable in this area as you can see in my first post then help me by telling me where to bring it
DIGI what do you wan tme to do ??? Im under a year by one month
Old 03-04-2004, 09:58 AM
Old 03-04-2004, 10:50 AM
Psax2 Psax2 is offline
I have the exact same problem, if you find any solution please post
Thanks
PowerBook 15' Mbox
<a href="link" target="_blank">www.studiosonica.com</a>
Old 03-04-2004, 10:56 AM
Hi
to get it fixed
Old 03-04-2004, 12:20 PM
birdFEEDER birdFEEDER is offline
And it is my understanding that core audio does not support midi
True. OS X has a dedicated system for handing MIDI, it is called: CoreMIDI. So a coreAudio driver will not give you MIDI capabilites, however, when I installed my 001, MIDI Drivers were installed in either
/Libary/Audio/MIDI Drivers
/Libary/Audio/MIDI Configurations
That may or may not help you in your current situation but might give a better understaning of CoreAudio vs. CoreMIDI.
Also, and I could be quite wrong on this, but I seem to recall reading that the one-clientness of the Digi-001 extends to Audio AND MIDI. Meaning, it might not be possible for TWO clients (one using Audio and the other using MIDI) to use the 001 at the same time, this would violate the one-clientness of the 001. To reiterate, I'm going from memory here, I'm very open to be corrected on that last point.
Hope that helps...
-bF
Old 03-04-2004, 01:43 PM
Twinstream Twinstream is offline
Good point....as I seem to recall early versions of PT 6 or core audio actually moved the midi driver out of the midi driver folder to unused Digidesign folder upon installation . You had to go in and put it back in the midi driver folder in order for midi to start working.....
its 12:30 in the morning ...
are you going to bed?
G4 733 Ti 1Ghz 001 Mbox LE6.4 OSX 10.3.8 QT 6.9 XP80 XV2020 Midiman 2 POD2 Logic 6.43
ProTools 8.0.4 doesn't send MIDI to Yamaha S90 ES; midi out ports [Emulated] bbirney Pro Tools M-Powered (Win) 8 05-19-2018 06:58 PM
Mbox 3 Mini stopped working on all USB ports The Confused Monk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-24-2012 07:59 AM
MIDI out ports not working in PT8 Vista! usastra Pro Tools TDM Systems (Win) 13 02-17-2010 01:51 PM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
002 Firewire ports not working after changing PS harness!!! postman56 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-13-2008 11:00 AM
