Old 05-07-2020, 03:37 PM
paulschwotzer paulschwotzer is offline
Default 2019 Mac Pro - Separate Audio Disk?
Today I learned that two SSD units in the new Mac Pro CANNOT be formatted as separate disk volumes.
Over the years Avid has advised putting audio data onto a separate disk... Not the boot disk. That was easy in a cheese grater with Four drive bays.
My question:
Is it still necessary to put audio on a separate volume?
For the new 2019 Mac Pro that will require disks in an MPX slot, disks in the Pegasus expansion module, or external USB/T-Bolt disks.
I am wondering if Avid has relaxed the "separate disk" requirement now that machines and data access is so very fast.
Will someone from Avid comment on this?
Old 05-07-2020, 05:18 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: 2019 Mac Pro - Separate Audio Disk?
" new Mac Pro CANNOT be formatted as separate disk volumes."
They should.
reboot in repair (Command R)
Address the new drives--
More details easily found...
Old 05-08-2020, 03:33 PM
With the speed of SSD's its not the show-stopper that it used to be. Having said that, DetroitT may be on to something, or why not just add an external SSD on USB3 or Thunderbolt?
Old 05-09-2020, 09:21 AM
I will use the single main disk for PT sessions and see how it works.
If problems I will use a separate disk.
I will post my findings in a month or so..
Paul
Old 05-09-2020, 09:12 PM
The PCIe/NVMe SSDs that you have in this Mac are so unbelievably fast that you will not run into issues putting sessions (and samples) on the boot drive. I've been asking Avid to update their out of date advice for years for folks working with super fast SSD and Avid just seem asleep.
You can mess with these SSDs and might want to for lots of reasons, increasing redundancy, installing multiple boot volumes, etc.
Old 05-10-2020, 04:58 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
Yes you can, ive done it... the new macpro with 2 ssd gets deliverd from Apple as one combined drive.
Ive seperated the 2tb into 3 partitions, one 1tb ssd has 2 partitions (500gb each) and one ssd has 1tb audio partition.
It means you need to start from scratch, install os again etc.
PT Ultimate 2024.03.0, Avid S1, Eucon 2023.11
16" MacBookPro (2023) M2 Max 12-core, 64gb Ram, 1Tb SSD, OSX 14.4.1
MTRX v.2.4.2.2 + dante card + madi baseunit + optical SFP 1300nm
MTRX-II v.1.0.5.2 + TB3 + 1x AD mic 8ch + 1x DA 8ch
MOM v.1.0.1.4 by DAD
Genelec 1237A Sam, Avantone active mixcubes
LA2a (1968), 1073 pre/eq, Neve RNHP, Wacom Intuos Pro
Furman P1400 AR E Power conditioner
Live-rack:
1x HD Native TB, 4x 192 I/O (64ch AD)
8x Yamaha HA-8 micpre, Rosendahl mif4,
Genelec 1031A, Presonus Monitor Station
2019.5 Different Disk Cache behaviour (depends on Parallel Task Optimizations) bartosz idzi Pro Tools 2019 0 05-16-2019 06:00 AM
Does Pro tools require a separate audio disk>? Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-31-2006 09:08 PM
How do I separate audio and PT files across different drives? JMS40 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-07-2002 12:20 AM
PC audio & midi: better together or separate? maxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-21-2001 03:13 AM
PC audio & midi: better together or separate? maxx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-21-2001 03:10 AM
