#121
Re: Play 4 AAX for PT 10 & 11
Trashing preferences and databases is a big help when things are going wacky. |
#122
#123
And as I told above, there might be a pb with 10.3.6 that doesn't exist anymore with 10.3.7 (so you didn't get it). This pb was solved with launching play4 Standalone in 32 bits mode (I posted this for users who could experience this bug). Of course.
Macbook Pro (Core2duo 2,4GHz RAM4GB SSD) MacMini (Core i7 Quad@2,3GHz RAM16GB SSD) PT 10.3.10 + PT12.4 / VEP5.3.1 / MacOSX.9.5 (MBP) PT12.4 / VEP5.3.1 / MacOSX.11.1 (MBP) PT 10.3.10 / PT11.3.2 / PT12.4 / VEP5.3.1 / MacOSX.8.5 (MM "Production" on SSD) PT 12.4 / VEP5.3.1 / MacOSX.11.1 (MM "test" on HDD) RME UFX (USB2 with MM and Firewire with MBP) + Vienna Ensemble Pro Server on PC Q6600/8Gb/Win7-Pro64-SP1 |
#124
With the most recent version of Play 4, the reverb bug has been fixed. Get that one. |
#125
If you don't experience any issues with the last Play4 release, just skip my posts. Thank you.
#126
#127
#128
I keep posting about it because you're saying things that make no sense. Running Play 4 in standalone has nothing to do with running it in a daw - you keep saying that it does and I'm saying it doesn't. I'm not negating your issues, just the bad info you're putting out there about how to supposedly solve those issues.
#129
hello guys
i had the eastwest support telling me play 6 would work fine with pro tools 11 to be able to use pop brass & hollywood horns but pro tools tells me cannot find authorization to run play. i emailed them but no reply so far any clues ? PS according to easwest pop brass only works with play in 64bits mode - i read somewhere in the duc someone had this solved running previous version of play but, i cannot find any links to download play 5
My soundcloud page Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8 Last edited by groovebrother; 05-26-2020 at 03:08 AM. |
#130
Notation view edit while in play cause play to stop working. | soybalm | Pro Tools 10 | 1 | 04-18-2013 11:11 AM |
Is it possible to play a click without pressing play, and have it in sync.... | ALowe | macOS | 5 | 06-05-2011 04:24 PM |
play flashes then stops. session wont play. | hellbert | Windows | 21 | 03-31-2011 10:49 PM |
When press play the stop key lite and play key blinking | Sam Yin | Tips & Tricks | 6 | 12-05-2009 08:26 PM |
I press play, it doesn't play. hehe - any advice? | awritersparadise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 02-11-2007 05:24 AM |
