Old 09-19-2007, 12:34 PM
prophonic prophonic is offline
Default Freezing / Printing Audio Tracks and RTAS Instruments
Hi Everyone,
For years, I have been trying to find a way of printing audio onto the same track (like a freeze track function) and it looks like I finally cracked it. We have been using it for a while ourselves and it seems to work well.
While we were searching for this we also stumbled upon a method for printing RTAS instruments onto the same track as well. For both of these we have just posted two tutorial videos on our website - they are not of professional quality, but they explain the methods fine.
The link for the videos is Pro Tools Tutorials
We tested this on PT 7.1cs7 - I would like to find out whether the technique works for other versions of Pro Tools as well.
Enjoy
Osman Kent
Old 09-19-2007, 01:44 PM
1m1 1m1 is offline
Default Re: Freezing / Printing Audio Tracks and RTAS Instruments
Very clever - I will be using this! One question... with delay compensation on, does the audio line up correctly with the original track?
Old 09-19-2007, 01:48 PM
You can make it sample accurate with the tips provided. PT does not seem to record frozen tracks with sample accuracy.
Osman
Old 09-19-2007, 01:59 PM
Steve MacMillan Steve MacMillan is offline
Thanks for that. It sure would be nice to have a proper freeze function without all the backflips.
STeve
macmandigital.com
Old 09-19-2007, 02:06 PM
No problem - we have been so excited with it that we wanted to share it with the DUC community.
As all the underlying mechanisms seem to be there inside PT7, it would not be too difficult for digidesign to incorporate it in some future release. Alternatively, if there was a macro/script function in PT, we as the users could automate the process ourselves.
Osman
Old 09-19-2007, 02:27 PM
What I have always done is dupicate the track without audio or inserts (but retaining sends, and fader & pan position/automation). Then assign a pre-fader buss send from the original track and record to the dupicate. Then I de-activate the entire original track.
The best thing about the Logic freeze feature is that it happens faster than real time. With TDM I'm sure that would be impossible.
STeve
macmandigital.com
Old 09-19-2007, 02:40 PM
That's a good technique too. However, in some our of sessions we are near the limit (we do everything 24-96) and even creating a single new track produces the dreaded DSP shuffle.
With the technique we described, you can print all the audio tracks at once (voices permitting). QP mode uses double the number of voices.
Osman
Old 09-19-2007, 03:17 PM
Stig Eliassen's Avatar
That's a great method, Osman.
Thanks for sharing.
Old 09-19-2007, 06:31 PM
DigiTechSupt's Avatar
Quite clever -
Thanks for the tip.....and the video is a nice touch!
Avid Audio Tech Support
Support FAQ
Old 09-19-2007, 07:17 PM
Sound-Influence Sound-Influence is offline
Brilliantly simple. One of those "why didn't I think of that" moments!
Great tip! I'm redoing my templates now-- this will be HUGE in my workflow!!!
Thanks for sharing!!
Aub
PT 7.4cs2 | OS 10.4.9 | Dual 2.0 G5 7g Ram | HD3 Accel | 4 FW800 Drives
Printing/Freezing tracks in PT9? JonesH Pro Tools 9 0 09-14-2011 02:56 AM
recorded instruments on audio tracks what should I do? phefner84 Tips & Tricks 2 08-07-2011 11:22 AM
Delay Comp on or off for Printing RTAS Instruments and doing Odubs in PTHD8.01? drdolla80 Pro Tools TDM Systems (Mac) 2 10-23-2009 03:32 AM
Printing Strike Audio To Tracks RussUK Virtual Instruments 0 05-28-2009 04:38 AM
"Freezing" and "Printing" tracks... any good tips? Metanaut Pro Tools TDM Systems (Mac) 3 03-28-2005 11:02 PM
