ReVibe native/AXX
When the heck is avid going to finally relase this!
Re: ReVibe native/AXX
I'm pretty sure they will release it when the HDX cards are released, which should be in the next week or so.
If I remember correctly, one of the Avid guys said that in the live AES webchat. |
So - do I have to upgrade to PT 10 to take advantage of Revibe/ReverbOne in native? Will my existing license be enough? And do I have to have any other hardware for it to work? Or will there simply be a Native version in my plugins folder?
Thanks!
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
PT9 will not run AAX plugins. They will run on 10 if you have TDM licenses! But are really only intended for HDX cards, but seem to work on non HDX as native but with quite a high CPU hit for revibe as it was an accel plugin! Chris
Ha! Forgot all about this. Wasn't there another plug that was going to be released as native AAX? Aside from Channel Strip, ModDelay3, and downmix.
Forgive my ignorance. I'm just getting into ProTools 10 now. So AAX is ProTools 10's new term for native? And basically put ReVibe and ReverbOne are being ported from TDM to AAX? Will our TDM license still open the AAX version?
AAX is the new plugin format for HDX cards. There are AAX DSP that run off the cards and AAX native that run off the computer CPU. The native versions will also run on non HDX systems. Revibe and reverb one are out now as AAX specifically for HDX card users but also work natively on non HDX systems. Chris
I an confirm that Revibe and Reverb One will run on my Protools X CPTK (in Native mode)MacBook pro running Mac OS 10.6.8 using my existing TDM Ilok assets.
One instance of Revibe sucks 14% CPU I haven't got as far as seeing what multiple instances will do. |
Native AAX Revibe, etc... | Audio_Vision | Pro Tools 10 | 33 | 05-22-2012 08:22 PM |
HD Native and ReVibe (amongst other TDM only plugs) | paranerd | Pro Tools HDX & HD Native Systems (Mac) | 9 | 01-14-2012 11:34 AM |
Revibe, Reverb One Native? + C24 | Mubeau | Post - Surround - Video | 1 | 03-24-2011 05:16 PM |
Revibe Native, when!? | Cryos | Pro Tools 9 | 2 | 03-13-2011 08:17 AM |
Revibe Native, when!? | Cryos | Pro Tools 9 | 3 | 03-12-2011 04:31 PM |
