New Avid MBox Sample Rate Problem
New Avid MBox / PT 8.0.4 cs2 / OSX 10.6.4 / MacBook Pro 2.4 intel Core 2 Duo
Not sure if this is a global problem with all boxes or just a bad box that I have. Sessions set to 48K play back slow. Checked the spdif out sample rate, turns out it's actually 44.9 and not very steady. Sessions set at 96k also playback slow. no problems with 44.1 Checked the spdif out sample rate, 44.1 solid. haven't checked 88.2 So it looking like the 48/96 clocking is bad. Anyone else seeing this problem? |
Re: New Avid MBox Sample Rate Problem
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
In the test the original audio was recorded at the specified sample rates.
The tech at the studio checked the actual sample rate with a meter. The sample rate is wrong @ 48 k the MBox is clocking at a unstable 44.9k. This is a hardware problem. |
I have the same problem with my avid Mbox. The session plays back fine when I connect my 003 or MBox mini..
It's a problem with some of the MBox 3 units. A small portion of them seem to be affected by this sample rate issue.
Contact AVID or your dealer where you bought it from and they will exchange it with a new one. There's a few threads on here about it. |
Thanks for the info!
Ok so I returned and replaced the MBox with another.
Guess what - 48K plays at the wrong speed and 96K plays back with digital hash all over it. I played the same sessions back on a digi 002 all good. So this hardware problem that's supposed to be in a FEW of the new Avid Mboxes seems like it may be a bit more wide spread than advertised. |
They've been pretty good to a few people with this issue - so I hear. |
well just bought the new m box 3 and i am having similar issues , when i set a session up at 96 khz and import a instrumental no matter what sample rate i select it plays back in slow motion any thing above 48 khz plays sped up even when i set up a session at 44.1 and import a instrumental at 44.1 it still plays in slow motion can anyone help me with this situation is anyone else experiencing this ???? is this a defect within the m box 3 ???? and will avid replace it if it is ???? i purchased it from guitar center and they say they wont replace it or refund my money because i already installed the software , therefore will avid take care of it ???? from what i understand i only get one support call ????
Hi guys,
I know this an old thread but I'm replying to this it Sandra report) and I haven't received any responses. I just want to know is there a setting adjustment that I'm just not familiar with in the Mbox3 or is it hardware issue that causes 48k to sometimes playback slow?? It never seems to be a problem with 44.1k files or sessions. It happens on every computer that I've tried with this new Mbox. Cheers, Joe |
Avid HD ASIO Driver Locked Sample Rate | Keith Moore | Pro Tools HDX & HD Native Systems (Win) | 10 | 11-16-2013 12:53 AM |
HW device is different sample rate AVID | john1192 | macOS | 3 | 10-15-2013 11:41 AM |
Sample rate problem with MBox 3 and Logic | jejansse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-19-2012 09:25 AM |
MBox Micro Sample Max Sample Rate Only 48 kHz? | Joe Sciacca | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-07-2008 12:52 PM |
Bit Rate/Sample Rate problem? The chipmunks? | bspro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-17-2008 05:40 PM |
