question on achieving a digital vocal effect?
hello I am looking to do a vocal effect for a song that sounds like a digital stutter or like the matrix when mr. anderson swallows the mirror or whatever if anybody knows what I am talking about. can anybody give me ideas or tips? thanks
AMD Phenom(tm) II X4 955 Processor 3.21GHz Gigabyte GA-790XTA-UD4 Total Memory : 4GB DIMM DDR3 Memory Bus Speed : 2x 670MHz (1.34GHz) western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (C:) western digital black (1TB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 932GB (D:) Memorex DVD+-RAM 550L v1 (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Windows 7 Ultimate 6.01.7600 x64 gateway 24inch hdmi dvi HD monitor pro tools LE 8.0.4 |
Re: question on achieving a digital vocal effect?
Stutter will be achieved with abrupt cuts and repetitions of parts of words with small gaps in between.
I'd say the matrix effect you're talking about would be achieved by time stretching a word really far out and then applying a slow pitch shift up over the lot (AIR frequency shifter would be perfect for that). Hope that helps...
se.audio |
I may be wrong, but I thought I saw that Izotope has a plug for that.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
I figured doing it manually could work but would rather use a plugin. thanks to all and will try out things. thanks
Yeah iZotope has just released Stutter edit, which would probably achieve the same effect after a bit of tweaking... but people were doing that efect long before that plug came out
se.audio |
People have been doing this for years, but it was very tedious. As mentioned, it was done by cutting out parts of the vocal.
Stutter Edit makes it much easier and faster, and allows you to randomly do it on the fly, and does a lot of other cool things for not much money. |
Since the early 90's this was achieved w an eventide h3000. It has an outright patch called stutter.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
If you're talking about when he swallows the pill, then I kind of thought that sounded like a ring modulator... maybe combined with the stuttering effect (and some pitch shifting)?
It's been a while since I heard the movie..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
you know what yeah that did sound like that. I meant a stutter then haha will check out izatope they are cool plugins
If you refer to the scene when Neo (Mr Anderson) was on the seat, just before he wakes up in the real world....
This effect is more than a stutter...For me it's more like a Bitcrucher applied with automation. You can achieve that with the plugin Speakerphone from Audioease. With it you can achieve a virtual bitdepth drop from 24bit to...Let's say 4bit (it depends on how much degradation you need).
Green Room Studios, France Mac Book Pro i7 15"4 Mac OSX 10.6.6 PT 9.0.2 DIY Intel Core 2 Quad, P5B Premium,DDR2 6GB, Win 7 Ultimate. PTLE 8.0.4 002R Unit and MBox Mini SSL XLogic Alpha Channel. SPL Goldmike valve Preamp. DBX Analog Compressors, Gate and Eq. Monster Cables Home made & Neutrik Patchbay. Brauner, Shure, Seinnheiser and T.Bone mikes. Tannoy 8D Active monitors. |
Getting a Certain Vocal Effect | DonaldM | Tips & Tricks | 14 | 05-22-2013 01:13 PM |
Achieving this panel effect? | primomusic | Pro Tools TDM Systems (Mac) | 17 | 12-26-2012 01:43 AM |
Achieving a tape saturation-like effect in PTLE | Tubthumper | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-04-2004 04:51 AM |
"Digital" Vocal Effect...? | platinumx99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 11-19-2002 12:14 AM |
Finally a new vocal effect to put the Cher effect to bed!!! | ***BboY *** | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-22-2002 09:11 PM |
