Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 05-04-2020, 07:35 AM
oortone oortone is offline
Default Snap Sync point to grid only one time?
Hello.
In absolute grid mode, if I have a clip with a sync point it will only snap the sync point to the grid the first time I move it. After that, once selected it will snap the start to grid instead.
Can this be changed so it always snap sync point to grid regardless if selected or not?
EDIT: This only happens to me when I have fades at the beginning of clips.
Old 05-04-2020, 07:43 AM
Default Re: Snap Sync point to grid only one time?
Not sure I understand your question, but could Relative Grid be the solution?
Old 05-04-2020, 09:19 AM
Hello, no that doesn't help either.
If a clip is not selected then when I grab and move it the sync point of the clip is snapped to the grid.
If it the clip is already selected when i grab it then the start point of the clip that is snapped to the grid instead. This I do not want since it forces me to unselect the clip all the time while moving the clip around in the grid.
Old 05-05-2020, 03:43 AM
Addition: Seems like this only happens when there's a fade at the beginning of the clip. Without fades it's as I would expect.
Old 05-05-2020, 09:57 AM
Sonopolis Sonopolis is offline
Yes, I can reproduce this. It seems buggy. I should neither make a difference whether there is a fade or not, nor if you newly select the the clip or it already was selected. The manual states that once a clip has a sync point, it should always snap to grid with it.
As a workaround, I guess you know about ctrl+Grabber click and ctrl+shift+Grabber click I suppose?
Old 05-06-2020, 04:19 AM
Ok, good to know it can be reproduced.
I don't use Pro Tools on a regular basis so I'm not aware of those commands but I´ll chet it out next time,
Edit Mode difference between: Grid and Slip+Snap to Grid zenstone macOS 0 02-05-2015 04:34 AM
"Waiting Sync Point" trying to chase time code? Matthew Steel Pro Tools TDM Systems (Mac) 4 12-05-2007 01:45 PM
How to snap several regions to a sync point (PT 6.9.3) sauna-l Tips & Tricks 5 05-17-2007 09:46 AM
Repeating Regions w/ sync point grid reference deanguidry 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2006 04:31 PM
Snap sync point to sync point? imi Tips & Tricks 3 05-25-2003 06:48 AM
