Old 12-19-2007, 07:10 PM
Steve7 Steve7 is offline
Default External Hard Drive for Macbook and 003
I've been recording a lot and my 80gig MacBook is running out of space. So I'm considering a external hard drive. Will this one work with my 003 and ProTools LE?
http://www.newegg.com/Product/Produc...82E16822148168
I'm looking for something very inexpensive but also reliable.
Thanks for the help.
Old 12-19-2007, 07:18 PM
OddsAre OddsAre is offline
Default Re: External Hard Drive for Macbook and 003
FIrst of all it should have been the first thing you did after purchasing Pro Tool. Its a bad idea to record to the system drive. Second of all you HAVE to use a Firewire drive and it is HIGHLY recommended to find one with an Oxford 911 Chip in the enclosure.
This is the drive I recommend most:
http://eshop.macsales.com/item/Other.../ME2FW7160GBJ/
Bullet proof, No Fan so its quiet, and has an Oxford 911 Chip in the enclosure. Spend the extra dough. Its like buying crappy tires at Walmart or buying Michelin's from the Michelin man. I guess you could choose one over the other, but one is a better choice than the other.
Mac Book Pro Retina 2.6 GHz i7 Quad | 16GB | OSX 10.8.5 | Digi 002 | Apogee Rosetta 800/96 | PT 10 | Waves Gold/RevMaxx V9
Old 12-20-2007, 08:38 AM
Thanks. The price of that isn't too bad.
Does anyone recommend any other external firewire hard drives that might be cheaper?
Thanks alot.
Old 12-21-2007, 01:00 AM
GTBannah GTBannah is offline
Thanks alot.
No.
Derrkins
GuyBarTola
PT 2018; Nuendo 8.?; Studio One 3; former Sonar and Sequoia user .... GENELEC 1031A, AVANTONE MIX CUBES (Active); Sibelius 7.0; Dorico; Mac Mini 2.6 GHz Core i7, OS X 10.12.2 Sierra; 16GB RAM; 480 GB System SSD; 1 TB 7200 rpm Audio; 3 TB samples; Roland A-800 Pro controller; GOOD BYE PEE SEA!!
Old 12-22-2007, 05:32 PM
yanncrusoe yanncrusoe is offline
that hard drive is cheap is chips man
MBP 17" 2.4 ghz, 320gb 7200 , 4 GB RAM, Glyph GT050Q, 10.5.7
Mbox2, PT8cs3, BFD2
www.myspace.com/yanncrusoe
6085 error, using macbook pro + external hard drive + profire 610 ahjteam macOS 5 10-17-2012 01:02 PM
Macbook + 003 + external Hard drive question (if you have this set up please help) Atlas Dan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-07-2010 06:52 PM
Best way to configure new macbook pro, mbox 2 pro, external firewire hard drive? Schragermeister 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 59 07-11-2009 08:01 AM
external hard drive recommendation for MBox 2 Pro new macbook pro maharzan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-30-2009 06:23 AM
External Hard Drive Selection/One Ext. HD for MacBook Pro? Gab4Pay Storage Subsystems 0 09-16-2007 12:18 AM
